NOTCH to be or not to be?????
Old October 13th, 2010, 10:33 PM   #1
1987mustanggt's Avatar
1987mustang gt
1987mustanggt is on a distinguished road
Angry
OK so their selling me a 4 banger notch.. but with the ugly red interior but it doesnt have motor or trans... they want 750 for it....i can get a manual trans for it...its an automatic..so my question is is it worth buying?????? and how much or how hard would it be to convert it to a standard..the only thing i would need is the motor...ohh and do this have the 8.8 rear end????and if i put 5.0 motor does it go in easy or are there any special things or parts ill need?
Old October 13th, 2010, 10:39 PM   #2
1987mustang gt
i dont wanna spend over 2000....in total...
Old October 13th, 2010, 11:10 PM   #3
WhiteMamba's Avatar
88 Notch
WhiteMamba is on a distinguished road
gonna be more than 2k total bro...figure a good motor is around 300-400 in decent shape plus install of that and the rear end...
88 Notchy
306 with 70mm Turbo
510 RWHP on 10lbs
K thnx
Can we chat?
Old October 13th, 2010, 11:17 PM   #4
1987mustang gt
ok i forgot my uncles r mechanics...so labor no problem...ok so i need the rear end and what else...?????? do the notch motor mounts go wit the 5.0 motor??
Old October 14th, 2010, 12:44 AM   #5
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
8.8 rear end is going to be 200-400 depending if you pull it from a junkyard, or buy from soneone that did.
motor is 200-500 depending. a NEW crate motor can be $2k. A well built motor is around $7k with good h/c/i and all the goodies.
my AOD to T5 swap cost me around $2500.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old October 14th, 2010, 04:19 AM   #6
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
was that all new parts?
Old October 14th, 2010, 06:03 AM   #7
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
i got my notch for 1000 with a popped trans. IMO, 750 is a lot for a roller. I would say it would be worth while if you had a donor car and could get the notch for no more than 500. suitable donors could be t birds and cougs from the same year or you could get a setup out of a newer car with mas airflow.
i would wait for the car you want instead of building the one you want. i think you can get yourself a rough 5.0 stick for 2k that you could chip away at. (dont forget that on top of that drive train you are going to need to overhaul or upgrade that 20 yr old suspension)
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old October 14th, 2010, 10:14 AM   #8
1993 mustang GT
vtwinjunkie is on a distinguished road
converting to a 5.0 you also need to upgrade the front end as well if you want it to stop.
Old October 14th, 2010, 10:36 AM   #9
1995 Mustang
laser95 is on a distinguished road
I think that you could also stay on a low budget by going carb'd vs going efi on the 5.0 swap
Old October 14th, 2010, 05:39 PM   #10
ryanw's Avatar
1991 Ford Mustang GT
Its cheaper yes... but dont do it
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 15th, 2010, 08:29 AM   #11
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Don't do it. It's an interior you don't like, an automatic, and still has 4 banger springs. You'll need to dump in a motor (300-500), transmission swap (clutch,pedals,flywheel,transmission etc. 1,500-2,500) and then do all the work. So I would just keep searching or waiting.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Threads Similar to: NOTCH to be or not to be?????
a notch away White Thunder Pictures 57 May 15th, 2011 07:18 PM
maybe a notch SWEET2KSTANG The Clubhouse 4 March 14th, 2009 07:08 PM
Notch to get 88 v8 3521 5.0 Mustangs 14 December 21st, 2008 02:45 PM
Best looking notch White Thunder 5.0 Mustangs 42 December 18th, 2008 05:02 PM
