Temp Sending Sensor
Old October 14th, 2010, 10:52 AM   #1
95project is on a distinguished road
Temp Sending Sensor
Got a digital gauge from Summitt...where can i install the digital sending unit? Isnt their a plug on the bottom of the block that i can use?
If i remove the analog one in the top of the intake and replace it with the digital and dont use the stock gauge will i have any issues?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing.
Old October 14th, 2010, 10:56 AM   #2
1992 Lx
11.39@119.24
nope thats what most people do. It should come with some adapters so itll fit in the stock hole. The sensor on the driver side is for the gauge, the sensor on the pass side in the heater tube is for the computer
Old October 14th, 2010, 11:08 AM   #3
awesome...i thought the one on the drivers side went to the computer too...
This just got much easier..
thanks
Old October 14th, 2010, 11:24 AM   #4
EscortSportage's Avatar
1989 Mustang GT 5.0
passenger side on lower intake, where the stock sending unit is where u have my coolant guage plugged into
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old October 14th, 2010, 12:44 PM   #5
if your standing at the front of your car looking at the motor, the sender on the lower intake to the right of your dizzy is the one that goes to the dash gauge. If you replace that one with your digital aftermarket gauge sender then the one in the dash that sucks balls will no longer function but you won't have any issues.
Old October 14th, 2010, 09:37 PM   #6
1989 Mustang GT 5.0
yes, this is exactly what i did AEM digitol love it
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old October 15th, 2010, 12:30 AM   #7
1992 Lx
11.39@119.24
quit hating on the stock temp gauge guys I like mine
Old October 15th, 2010, 06:57 AM   #8
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
you guys all need to stop for a second...
the majority of aftermarket intake manifolds have 3/8" NPT ports drilled into all 4 corners of the manifold... right where the coolant passages are.
Use one that DOESNT have a sensor in it.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Threads Similar to: Temp Sending Sensor
Temp sending unit gtstangrunner 94-95 20 May 20th, 2009 12:03 PM
Temp sensor going out? Mr. Zip V6 Mustangs 0 March 16th, 2009 12:31 AM
temp sending unit egghead 96-98 2 February 26th, 2008 09:42 PM
water temp sending unit Superfly76 99-04 23 April 30th, 2007 12:01 PM
no temp sensor how to connect one? roscoe 5.0 Mustangs 2 February 14th, 2007 09:04 PM
