dip stick blowing out at wot
Old April 7th, 2007, 03:35 PM   #1
Flavian is on a distinguished road
i have a 347 stroker with a novi 2000 blower and im runnin right around 11 lbs of boost.. i recently started having a problem with my dip stick coming up and oil going every where under wot.. any suggestions on an evac system..? thanks
Old April 7th, 2007, 04:41 PM   #2
GTXRacing is on a distinguished road
I have the same issue and I just get some of that bluw RTV stuff and just add a thin layer of that around the tube, then I add a large O ring. You could go to the ford house and just order a dipstick gasket fitting but why pay the 15 bucks for a piece of rubber.
THE BEAST IS FOR SALE!!!
GTX RACING & PERFORMACE CLUB OF TEXAS
Meets and greets, drag racing and good eats, you know you want it.
GTX Racing
Tony P.
214-257-3635
http://www.moddedmustangs.com/forums...vehicle&CID=43
Old April 7th, 2007, 06:51 PM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
What kind of evac, system are u running(stock PVC, breathers)? Your building mucho pressure under your valve covers and it has no where to go. The dipstick is obviously the weak point. Better fix that cause the next likely spot for the blow by will be a rear main seal or timing cover front seal.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: dip stick blowing out at wot
New Mustang! Blowing some smoke. BrianNV 5.0 Mustangs 4 April 25th, 2007 12:03 AM
BLOWING A FUSE sgar Audio/Video 2 March 17th, 2007 09:24 AM
PLEASE HELP/BLOWING A FUSE sgar General Tech 1 March 16th, 2007 11:58 PM
a/c blowing thur def new 5.0 5.0 Mustangs 7 December 20th, 2006 10:44 AM
Im having a blowing problem...lol 68 dlxcoupe General Tech 6 July 13th, 2006 06:19 PM
