trick flow high port heads anyone?
Hi I was wondering if anyone on this site has heard of or is running trick flow high port iron heads. they are not made anymore but i have heard they are some of the best sbf heads around. anyway I was hopin someone could give me a little info on them? and if you thought this is a good buy?
Not the best around but they are good heads.
1993 Notch, 1988 Notch
Is there any truth to the rumor that they have discontinued production on this head?
The iron head they discontinued a while ago but they still make the aluminum hi ports.
well i have heard that although u need custom headers and u might have some clearance issues they are worth the trouble the old iron ones?
I would stay away from damaged heads unless you can have a machine shop give you an estimate on what it will cost to fix them. There might be more hidden damage to these heads that you will not see until you have them checked out.
thanks Darrell. I was also wondering if maybe you knew anyone who was using them and or knew of any sites that may have dyno numbers?
Threads Similar to: trick flow high port heads anyone?
| HELP! 5.0 w/trick flow heads..Rockers setup wrong? Pushrods? | 1slowhatch | 5.0 Mustangs | 16 | March 3rd, 2009 10:08 PM |
| whats the cfm for trick flow heads | White Thunder | 5.0 Mustangs | 44 | October 18th, 2007 10:59 PM |
| Trick Flow Top end kit. | Timm10221 | 5.0 Mustangs | 23 | October 17th, 2007 03:36 PM |
| trick flow | Iownastang | 5.0 Mustangs | 7 | July 6th, 2007 01:50 AM |
| Tuning Issues 5.0 w/trick flow heads | 1slowhatch | 5.0 Mustangs | 2 | April 23rd, 2007 12:56 PM |
