Need head & cam suggestions for 302 HO carbureted - Forums at Modded Mustangs
post #1 of 14 Old October 22nd, 2010, 03:23 PM Thread Starter
Guys im sorry if this has been posted and answered a 100 times. This is what im working with...A stock 302 HO shortblock out of a 90 GT with 85k...I tore it down and had the block cleaned, rehoned, magafluxed and installed new std bearings, cam bearings, rings, reused the factory rods and forged pistons, polished the crank...I know the E7 heads are a waste of time to port since the gt40's are available for reasonable prices...+ my bbk shorty should fit the "40P's". My coupe is an 88 with speed density, id rather run a good carb set up and keep it simple...Im looking for at least 300hp at the fly....no alphabet cams, what cam, intake and cfm carb would be great for a street/strip toy for low 13's or high 12 ET's...my car already has electric fan, 2 1/2'' exaust with H-pipe,no cats, 40 series, MSD 6A ign, crane cams fireball coil, and supposedly the rear end has a spool but im unawhere of the gear ratio....i bought this car with no engine, and it has the t5 btw...any help would be awsome...thanks
Five.Slow88coupe is offline
post #2 of 14 Old October 22nd, 2010, 03:35 PM
StangBanger302's Avatar
Edelbrock makes good intakes. And a barry grant carb will do you good. A 650 will be fine.
N/A or N2O Iron headed SBF coming summer 2015....Long ass build
StangBanger302 is offline
post #3 of 14 Old October 22nd, 2010, 03:40 PM
if all you want is high 12s go with the gt40 junk and a stock cam
93hatch is offline
post #4 of 14 Old October 22nd, 2010, 04:06 PM
Yeah, the stock cam is pretty efficient. Put higher ratio rocker arms on there and you will have a "rough" idle too. Nothing crazy, but you get sound out of it.
post #5 of 14 Old October 22nd, 2010, 04:30 PM Thread Starter
Thanks for the input...the car came with a holly 600 and a performer 289 intake lol, not even a RPM! I might go with the RPM air gap...is a ED 750 too much for the mild cam with gt40 heads? I like that Holly 650 DP but its 500 bucks!
post #6 of 14 Old October 22nd, 2010, 04:31 PM Thread Starter
Sorry, EB 750cfm
post #7 of 14 Old October 22nd, 2010, 04:38 PM
Try one of these http://www.barrygrant.com/demon/default.aspx?page=10
post #8 of 14 Old October 22nd, 2010, 04:53 PM Thread Starter
Im going with lunati or comp cams...just need to determine my top end combo for which cam to choose....i herd the pro comp heads are cheap and junk for aluminum heads...im probably going to find rebuilt gt40's for 500 on ebay with .600 springs
post #9 of 14 Old October 22nd, 2010, 04:56 PM Thread Starter
btw, this is a budget build...cant afford 1200 dollar aluminum heads....just want gt40's with mild lunati or comp cam with rpm intake and carb....eventually ill convert to mass air EFI when i can afford to put more money in her...
post #10 of 14 Old October 22nd, 2010, 07:57 PM
horsepowerjunkie's Avatar
I just put togather a similar set up for my 82 Capri RS. I started with a 89 forged piston short block, added a new Melling oil pump, a Comp XE266HR cam(216/224 @ .050 w/ .544/.555 lift), new FRPP timing chain, all new gaskets & seals, a new set of Trick Flow TW 170 heads, Edelbrock Performer RPM air gap, Mighty Demon 650, FRPP shorties, MAC off-road X-pipe, Flowmaster 3-chamber cat back, rebuilt T-5, 8.8 w/ 3.73's.
This combo runs great and makes awsome power!
89 LX Black, Dart 363, C4,T76BB, FAST EFI
86 GT Black, Dart 331, S-trim, 4R70W, MSII
82 Capri RS,306, N41, Fox Lake Stage 1 TW,T5,4.10's
73 Dart Sport 340, 410ci, Indy 360-2 CNC+
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
horsepowerjunkie is offline
post #11 of 14 Old October 22nd, 2010, 08:32 PM
I bet that car is fun as hell.
post #12 of 14 Old October 22nd, 2010, 11:23 PM
im running the demon carb also,i have dart windsor heads,1,7 roller rockers,bored 30 over and have a 582 lift on the cam,9.5to 1 compression but planning on bumping that up to 10.5 to 1 over the winter and im going to install a girdle in it,also probably going to change out my gears this winter,has 4:10s right now thinking on going with 3:56s
seans mustang
seans mustang is offline
post #13 of 14 Old October 23rd, 2010, 12:27 AM Thread Starter
All sound like great setups....I have all winter to build this motor...so money is the only factor of how fast I'll make my coupe & and how fast she'll be done!
post #14 of 14 Old October 23rd, 2010, 12:45 AM
when it comes to heads,intake and carbs,keep your eye out for used ones and save a small fortune on your build
seans mustang
Human Verification
