throttle
Old April 8th, 2007, 12:26 AM   #1
Look Ma! My First Post!
u-wish is on a distinguished road
throttle
Hey just joined how are all the mustang freaks doing? any slight problem maybe someone can answer. Throttle seems to be hard or sticky when you first push on it and every time you let off then back on again,only when the engine is running thow, works just fine when engine is off????
Old April 8th, 2007, 02:07 AM   #2
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
welcome the MM.
you could check your throttle cable out .. maybe clean up some of the dirt between the cable mount and the t/b.
adjust it ... ect
Old April 8th, 2007, 05:21 AM   #3
Bill is on a distinguished road
i had something like that problem. the pedal wouldnt moved down with out really pushing it. turned out the butterfly valve was getting stuck shut. my idle was messed up tho and the valve was totally shut. look into the throttle body(clean it, inspect it) look in to the throttle cable ect.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old April 8th, 2007, 09:04 AM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
if you cranked your throttle down too far they tend to stick.
Threads Similar to: throttle
Throttle Lag superpede1 V6 Mustangs 21 August 30th, 2007 03:31 AM
70 mm 75 mm throttle body mustang03GT 99-04 22 August 10th, 2007 06:01 PM
Throttle Body autoranch 96-98 4 August 7th, 2007 08:24 PM
1st mod... CAI or Throttle body? Killer_Bee V6 Mustangs 4 August 4th, 2007 07:03 PM
Throttle Body donny82277 Modular Mustangs 3 January 30th, 2007 07:38 PM
