1992 Mustang LX Hatch
Big Cams
Hey guys I was reading around this forum and others about camshafts, basically trying to get a little self-education before hopefully buying a fox in the spring. I noticed people kept referring to "big" cams as not being "streetable", and being difficult to drive with. I like big cams. That lopey idle is one of my favorite elements of any bad@ss car, and I am just wondering what all these people mean by a bigger cam being difficult to use on a daily driver. I understand that loping is due to overlap of the intake and exhaust cycles, and that more overlap helps high rpm power and low overlap helps torque. Does this have anything to do with it? What makes certain cams difficult to use? What is best for the street? And also, is overlap good for a drag car? Thanks for all the help
1992 Mustang LX
13.0 @ 105
cam in stock 5.0 just a quick search...
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
#3 | |
1992 Mustang LX
13.0 @ 105
Depends on what you mean by "BIG" cam.
Big like high lift/duration, like a .520 lift cam with a ton of overlap
1988 lx
9.68@142
sound or "lope" should be a bi product of having the right cam for your combination.. if you want to slow the car down and loose horsepower just for sound then you are missing the point.
the words big or small should be used in conjunction with the combination of parts it is going with. if i were to put my penis in a fat black girl she would proly call it small but if i took it to a tiny asian girl she would proly say it was........ small but for arguement sake well say big........ but then you bring it to my wife its just right for me cause i am uausally just doing it myself ayway but you get where i am going.. build the car then buy the cam last. cams are not cheap in the big picture..
Ok once again thanks for the reply, and nice analogy lol. But still I understand that the cam is the" brain" of the engine, what I don't undrerstand (and what I was asking about) is why people who do have a built car argue that a cam is too "big" to be "streetable" when discussing cam choice. I also understand that a high-lift cam in an automatic has to pull hard against the engine resulting in having to hold the brake pedal down harder than normal, but in a 5-speed why is it difficult to drive a built car (I might buy one pre-built but I need to understand why it will be more difficult for me to drive)
1988 lx
9.68@142
when people use the term too big to be streetable that means that the car reacts so poorly at low rpm and idles horrendus that it is very uncomfortable to drive daily. also sometimes with larger lift cams they dont produce enough vacuume to run a break booster and manual breaks just dont work as well.
but a good cam grinder can make a lopey cam that is still streetable.
89 GT
With a 5 speed you can also get bucking at low RPM's while in gear with some cams.
#10 | |
1990 LX hatch
I would think a big cam is any cam that pushes the minimum tolerance for PTV clearance.
1993 mustang lx hatchback
n/a
for example...this is CAMZILLLA-ford racing z-303(its crazy)
#13 | |
1990 mustang gt
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1986 lx notch
9.98 @ 135
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
#15 | |
1969 Mustang Mach 1
6.824@101.61
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
2006 GT
11.99@114
NAh don't educate lol. Let him be a fan cars that sound as slow as they are.
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
#17 | |||
1969 Mustang Mach 1
6.824@101.61
My cam is a little over .600 lift, and while it's not a "baby cam," there are people running WAY bigger cams than that.
1986 lx notch
9.98 @ 135
3/4 cam FTMFW !!!!!!!
1990 LX hatch
My cams lobes are gonna be so big, it wont make it past the first cam bearing when I try and install it.
Threads Similar to: Big Cams
| Big blocks cams need i say more? | Applehead281 | Videos | 13 | July 11th, 2010 07:28 AM |
| 278 Comp Cams too big?? | mtw002 | 99-04 | 77 | October 14th, 2008 12:18 AM |
| SCT's Big Air Meter -BA3000 BIG AIR MAF | obdnanr | V6 Mustangs | 26 | February 14th, 2008 04:17 PM |
| so, big cams | 93fourbangerstanger | 2.3 Mustangs | 4 | August 1st, 2007 01:04 PM |
