timing
I'm having a issue determining which way advance is on my dizzy. Does any one know if advanced is clockwise or counter-clockwise. Also if you could give me your opinion on a 10 degree advance or 15 thanks.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
1990 GT Convert
What due you mean about not knowing what direction to turn? Are you not watching the damper pulley as you turn? And 10-12 should be just fine. You dont want detonation so if she starts to ping under load you need to back it off.
As far as advancing spark which direction is advance. Is advance BTC or ATDC. If i know which one of these is advanced then ill be able to determine which way i have to turn the dizzy to advance it. thanks.
I have the dizzy out of the car cant crank the motor it will take me off TDC and then I'd have to find TDC all over again I know I'm lazy lol. I'm turning the crank with a ratchet.
Advanced is clockwise and the roller 5.0s love timing and can take up 22* advanced thats with the pill in.
Threads Similar to: timing
| need timing help bad!!!!!!!!!!!!!!!!!!!!!! | sloppyjosey | 5.0 Mustangs | 18 | October 23rd, 2007 06:34 PM |
| More Re-timing help | 97redgt | Modular Mustangs | 1 | September 9th, 2007 09:24 PM |
| timing | punkafi888 | V6 Mustangs | 13 | March 29th, 2007 02:01 AM |
| need help on my timing????? | tag team | 5.0 Mustangs | 3 | March 26th, 2007 01:04 AM |
| Timing | weems | 5.0 Mustangs | 10 | October 14th, 2006 12:26 AM |
