Antifreeze leak
Old October 25th, 2010, 11:53 AM   #1
1988 5.0 Mustang Coupe
Wilhelm is on a distinguished road
Antifreeze leak
Hey all,
So lately it's been getting cold here, and the other day it was around 40 degrees.
Well I started my car the other day when it was about 35-40 out. And I let it sit for a little while. I checked under the hood and there were no problems, leaks, or anything that I could see.
I drove about 1 mile to my friends house and I popped the hood to show him the engine, but it was leaking some antifreeze from around the water pump.
To me it seems like it's the gasket that's leaking. Is this a common problem? Or should I be worried?
Old October 25th, 2010, 01:05 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
nolife is a jewel in the roughnolife is a jewel in the roughnolife is a jewel in the rough
Around the water pump is a bit vague. The fan blows it around as well. It could be coming from the lower intake gasket and running down, a pin hole int he hose, the thermostat housing gasket, the wp gasket, or from the weep hole underneath the WP (alerts you that the internal seal is going bad).
Clean it all up, fill it up, start the car and let it warm up and try to get a better idea of the source. If it is the turns out to be the WP gasket or the weep hole, you should replace both the pump and gasket anyway.
You should fix it sooner than later, small leaks in coolant don't stay small leaks very long.
Old October 25th, 2010, 06:47 PM   #3
chickenbot's Avatar
1990 mustang gt
eventually
chickenbot can only hope to improve
i concur
1990 gt 5.0
Mac Performance 76mm straight shot intake
70mm Accufab tb and egr spacer
Trick Flow Track Heat u/l intake
3.55 gears
MSD distributor, Blaster Coil, and 8.5mm wires
Old October 26th, 2010, 03:04 PM   #4
Well it's a newer water pump, so I don't think it's the seal. But I will definitely check the rest of the things you recommended. Thanks.
Threads Similar to: Antifreeze leak
Antifreeze Leak? ralph30 96-98 27 August 21st, 2010 07:48 AM
Antifreeze leak I got pics now! justinsstang V6 Mustangs 21 March 14th, 2008 11:13 AM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 04:46 PM
Antifreeze leak japcrapkilla96 96-98 6 January 31st, 2007 09:25 PM
Antifreeze Leak magicman55 V6 Mustangs 4 October 19th, 2006 07:05 AM
