EFI to Carb gas lines
Old October 25th, 2010, 07:35 PM   #1
1991 mustang GT
14.12@99.89
91_FOX is on a distinguished road
been serching the forums for my friend and we cannot find what people are doing with the fuel lines for carb set ups. so heres my question, we removed the original 302 with the efi setup to install a carb'd 347. ordered the profesional products fuel regulator for efi to carb, is there some type of kit that comes with all the fittings and all the other fuel lines?
306, gt40x heads, msd ignition, gt40 intake, 75mm throttle body, 30lbs injectors, hooker shorties xpipe flowmaster 40 series,... SOLD.
Old October 25th, 2010, 08:27 PM   #2
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
call Summit and talk to them. they sell the fuel line adapters you need.
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Old October 29th, 2010, 01:24 AM   #3
Look Ma! My First Post!
1989 Mustang GT
12.89@108.89
FastFox351 is on a distinguished road
Fuel line issue:
Drop your tank, remove the elect. Fuel pump, place a chunk of rubber fuel line off the sending unit so that it reaches the bottom of the tank, you can use the factory lines but will have to cut the factory quick clip lines off at the pass side frame rail, the small line is a return so you can crimp it shut , I used braded covered fuel line from there across the steering rack and up to the mechanical pump( My local drag strip only allows 3" of rubber line under the hood so I used the an style look a like line to pass tech) You can also use your factory elect pump but will need a return regulator and have to run a new return like back to the tank( my car was a budget build 351 swap so I opted for the mechanical pump! Hope this is a help to you
Threads Similar to: EFI to Carb gas lines
efi to carb 89pigeontoe 5.0 Mustangs 1 September 13th, 2010 09:16 PM
carb vs efi Stang6er 5.0 Mustangs 5 April 2nd, 2010 08:34 PM
efi to carb gtstang87 5.0 Mustangs 4 June 5th, 2007 08:19 PM
EFI to Carb? 89fox5.0 5.0 Mustangs 4 February 8th, 2007 04:31 PM
V6 EFI vs Carb quikstang2 V6 Mustangs 3 August 17th, 2006 06:19 PM
