stroker kit balancing
Old October 25th, 2010, 07:38 PM   #1
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
so ill be picking up a '69 351w, and i will be stroking it to a 408w. the only thing i have some confusion on, is the balancing of the rotating assembly. i have an '88 Hatch with a 302, which is 50oz externally balanced, while 351w are 28oz externally balanced.
when i order the stroker kit, how should i have it balanced? i would like to transfer the balancer and flywheel from my 302 to the 408 stroker if possible. if i have the rotating assembly internally balanced, will i be able to do exactly that, or must i have it balanced for the 50oz external balance? if neither of those are an option, i assume i must succumb to the 28oz external balance, and i must buy a new balancer and flywheel to match. correct?
thanks for your help
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old October 25th, 2010, 09:14 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will need to use a 28 oz balancer and 28oz flexplate or flywheel. The balancer and flexplate/flywheel need to match. You can not use the 302 balancer.
Old October 25th, 2010, 09:38 PM   #3
'88 Mustang GT
im looking at CHP stroker kits. the one im intertested in only has the option for internal balancing. so could i use the 50oz balance then, or do i still need to swap to the 28oz balance?
Old October 25th, 2010, 09:52 PM   #4
HMERacing's Avatar
89 FOX/01 WS6
0@0/13.1@106
HMERacing is on a distinguished road
I believe if it is internally balanced you would need a zero balance crank and flywheel.
Mike
1989 Mustang LX, 2001 Transam WS6
Originally Posted by 302Army187 View Post
I'm going to install an U pipe.
bitch is going to re route the exhaust pulse back out of the intake between intake pulses.
Old October 26th, 2010, 02:06 PM   #5
'88 Mustang GT
if its internally balanced, wouldnt the external balances act as a neutral?
Old October 26th, 2010, 02:52 PM   #6
95StangMX's Avatar
95 Mustang GT
Yes you will need to have it balanced and you will need a 28 oz balancer and flywheel/flexplate like Darrell said. Best bet is to contact Jim @ FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines
Old October 26th, 2010, 05:32 PM   #7
'88 Mustang GT
sounds good. ill just swap to a different stroker kit, get it balanced for free, and pick up a new flywheel and balancer. thank guys.
Old October 28th, 2010, 11:26 AM   #8
95StangMX's Avatar
95 Mustang GT
no need to swap, Jim sells CHP, I bought mine from him, just have him get you what you need.
Threads Similar to: stroker kit balancing
stroker kit vs charger kit Mighty Stang 99-04 39 October 6th, 2010 10:49 PM
4.6 Stroker Kit tyler1987 96-98 19 April 28th, 2010 09:45 PM
Stroker Kit for me? 87StangLX 5.0 Mustangs 1 March 22nd, 2009 11:22 PM
Stroker Kit Chevyeater351@yahoo.com 5.0 Mustangs 8 November 8th, 2007 09:41 PM
4.6L Stroker kit energiesource 99-04 9 November 1st, 2007 01:22 AM
