LinkBack (2) | Thread Tools |
#1
1989 Mustang LX 5.0
slow..help
gt40 intake..
a friend of mine is trying to sell me his gt40 intake, fully ported and polished for roughly around 4-5 hundred.. is that a fair price? and i was wondering what kind of difference will i notice if i pick it up and install it... my fox is pretty stock, just a couple little things i did here and ther nothing crazy... i plan on doing the heads cam and intake, but dont have the money to do them all at once right now. i know in the long run, i would save quite a bit of money if i did it all at once while everything is already removed but unfortuantely i can't... any suggestions, tips would be nice.. thanks
1991 Mustang LX 5.0
NO!!! Unless it's the tubular cool looking one. They go for good money.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#3 | |
1991 Ford Mustang GT
Ya that price is alittle high. If your going to pay $500 then you can get a better flowing intake. Dont get me wrong the GT40 tubular intakes are great and in my opinion the best looking intake on the market. your pal sure isnt giving you the friend discount thats for sure.....
98 Cobra
If its not the tubular intake then don't pay more than 150 for the upper and lower, if its the tubular try and get him down to like 300-250
On ebay i do see them going for $400-$500 but i just dont think there worth it. what makes them run so high is because of the way they look and that they dont make them any more. But i agree with 91cobra5.0 who said above. if you can get it for like $300 then do it. Maybe even $350, you will all ways be able to get your money back at that price
1993 Mustang GT
I got my Streetburner for less than that, because someone here rocks
I have a 93 5.0 I love my car, and all my friends hate it. ![]() AEM Brute Force intake, BBK 75mm TB/EGR, C&L 75mm MAF, Trick Flow Street Upper/Lower, Custom exhaust with Dynomax SuperTurbos, Tokico Rear Shocks |
1989 Mustang LX 5.0
slow..help
thanks everyone. wouldnt really call him a friend to begin with, my fault. i'll try to talk him down, and if he wont go, i'll look into a different one. i believe he said he had a cobra intake for 200?.. what kind of impact will either one make on the car?
1993 Mustang GT
Hold on. Is it the GT40 tubular intake? Or is this an intake off of an Explorer that's been ported?
Because the Cobra is essentially the same. Just not as cool..
1989 Mustang LX 5.0
slow..help
well if its the one off of the explorer, i'm definitely not paying that kind of money for it. haha, i may be a noob, but not that dumb... i'm thinking of just going with the cobra.. another question, does anyone know what year they stopped putting the intake on the explorer, or do they still?
I think the cobra is just a cast version of the gt40. i have a cobra intake on my car. i like it but i dont have that many modd. they can be ported out alot. i ported mine to match a 70mm tb. the add when you buy them said that there good up to 350hp, but if you port the shit out of them im sure there good to over 400hp. but that doesnt mean that you cant get more then 400hp its just alittle harder then some of the other better flowing intakes. if you can get the cobra for $200 thats a good price and if you ever resell it youll get your money back
Also another good thing about the cobra intake is the EGR spacer is built into the intake so you dont need to buy one, every other intake you need to reuse your old one or upgrade to a bigger size to match a bigger TB. this will save you like 50+ dollars
1989 Mustang LX 5.0
slow..help
alright, what size throttle body should i go with ? and should i do the maf as well?
To tell you the truth i dont know. I read in a mag one time... and it said with a stock set up with only a intake and exhaust upgrade that 65mm was best. And that 70mm was good if you upgrade your heads and cam along with the other modds, and 75mm and up was good with a power adder with all the other modds. I forget the reason why the mag said not to put a 70-75mm and up on a stock set up. But every one here seems to say the bigger the better. So wait to get input from some one who really knows.
but keep this in mine. with a cobra intake you almost maxing out the porting at 70mm so if you want a bigger TB then 70mm you may want to go with a different intake. Because it doesnt make much sense to put on a 75mm or a 80mm TB on to a intake that only has a 70mm opening. BUT i will say that maybe its possible to port it bigger then 70mm but im unsure of that so you may want to check around and see if any ones gone bigger.
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; October 27th, 2010 at 01:20 AM. |
Im running a 70mm on my cobra and its opening is only 65mm but i measured it and it read a true 68mm so idk the 70 didn't seem far off if you ask me... Id check mine actually is getting fixed right now, i cracked it but i love it stock id say at least 10-15rwhp alot better in the higher rpms and i didn't sacrifice any torque.
1992 Mustang LX
13.0 @ 105
I would say get the cobra intake...Then get it ported by TMOSS on here. It will rival MANY aftermarket intakes. Go with the TB that fits the opening on the intake. If the opening on the intake is 70mm...Get a 70mmTB.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1989 Mustang LX 5.0
slow..help
thanks for the advice! my decision is definitely the cobra intake, the price just seems so much more reasonable.. do i have to get the throttle body at the same time? or can i put that on say for example in a week or two later.. the car is not a daily driver, maybe sees about 50 miles a week... the only reason i want to put it off, is because i got offered gt40 heads fully re done for what seemed to be a reasonable price 400$ so i was thinking of picking up both of these , the intake, and the heads and having them re done, and waiting on the cam and tb for another week or two later
1992 Mustang LX
13.0 @ 105
You can use the stocker in the meantime. If those heads are really "re-done" then hop on them. Verify with the machine shop that did them though. You can do a ported gt40head/intake combo and make it work. I've seen plenty of 300+rwhp with them and the right cam.
you can wait on the TB. just put your stock one on for now. you wont really feel a difference with the new intake untill you get some other modds done. the cobra is a good buy at $200
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/189586-gt40-intake.html
| Thread GT40 heads????? | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 21st, 2012 10:52 PM | |
| Ford Mustang Cobra Pictures | Ford Mustang Pictures - Part 5 | This thread | Refback | April 6th, 2011 07:30 AM | |
Threads Similar to: gt40 intake..
| gt40 intake | sickfox | The Clubhouse | 6 | February 16th, 2010 07:04 PM |
| gt40 intake | 1989Gt. | 5.0 Mustangs | 0 | May 31st, 2009 05:59 PM |
| GT40 INTAKE | 50COUP332 | 5.0 Mustangs | 6 | March 26th, 2007 10:23 PM |
