whats with the egr spacer
why did they run radiator hoses through the egr spacer and if you bypass that will you gain anything out of it just link the hoses together its on 90 gt thanks nate
The lines are to cool the exhaust gases that enter the intake system through the EGR. I would assume it also cools the entire spacer as well because it would get hot from those same exhaust gases running through and around it. Many people disconnect these coolant lines. Not sure why they disconnect them unless they disconnected the other parts of the EGR system as well and no exhaust gases are there to cool.
You need the cooler lines if the egr is operating.you will fail emisions on NOX if you remove it and the combustion temp will raise a little.It can be blocked off and removed it want hurt drivability check engine light may come on.
Im new at the stang ordeal thanks!!!!!!!
Disconnecting the lines will hurt you because the air intake temperature will increase.
2001 svt cobra
no way (IRS)
do you think it would be noticeable mr.darrell?. I connected the two hoses I was afraid coolant could leak into the air stream
Build #1249 MM New Edge Crew Member# 6 |
#7 | |
#8 | |
Threads Similar to: whats with the egr spacer
| Intake Spacer | 2000Mustang | V6 Mustangs | 8 | August 2nd, 2007 05:55 PM |
| spacer | droppedbass87 | Visual | 6 | May 15th, 2007 02:28 PM |
| spacer | mustang1072 | V6 Mustangs | 50 | February 10th, 2007 02:10 AM |
| Rust in EGR spacer? | Erron89 | 5.0 Mustangs | 5 | January 25th, 2007 06:42 PM |
| Oil in EGR spacer??? | Bill | 5.0 Mustangs | 4 | February 25th, 2006 05:19 PM |
