Whistling intake HELP - Page 2
Old April 9th, 2007, 10:06 PM   #21
sb2f5marine69's Avatar
sb2f5marine69 is on a distinguished road
Dont have one. Put a ron morrison performance eliminator kit on it.
Old April 9th, 2007, 11:13 PM   #22
ujslost's Avatar
I think its the mass air meter, when I had a pro-m mass air meter mine did the same thing. swapped to c&l meter and never heard the whistle again.
Could be CAI also
Old April 10th, 2007, 09:56 AM   #23
Ask All My Baby's Mommas
lineumup88's Avatar
lineumup88 is on a distinguished road
as far as you idle goes, swap out out your idle air motor and it that doesn't help try bumping your idle up to 850. sometimes when your idle is to low and you let off the throttle the iac motor sends the car into a surge trying to catch back up. i know it sounds stupid but it worked when i had that problem. as far as the whistle i have heard it on some and not on others and never found out what it was. good luck
hey chevy boy.....i got something for you to POWERSTROKE!
Warning: surgeon general says its ok to smoke ricers!
Old April 10th, 2007, 01:02 PM   #24
TurboLX's Avatar
1988 Mustang LX Turbo
when you put on a cold air intake, its gonna whistle because it is breathing that cold air and lovin it
Old April 10th, 2007, 01:03 PM   #25
TurboLX's Avatar
its just something they do for some reason, my ol' 306 had a cold air intake and it whistled after i put it on
Old April 10th, 2007, 01:21 PM   #26
B.A.M302 is on a distinguished road
Send a message via AIM to B.A.M302
The cold whistles because its sucking in so much air through the small screen holes of your filter that it causes that effect
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55,
Old April 10th, 2007, 04:27 PM   #27
1993 notch
joe 5.0 is on a distinguished road
I think i found it
its on the bottom of the throttle bodywhere the linkage hooks up
the throttle plate where it meets the shaft
try this wiggle the throttle bracket back and forth and see if the pitch changes
let me know your findings
Old April 10th, 2007, 10:18 PM   #28
cali 5.0 is on a distinguished road
y would it whistle, unless something is wrong with it, a whistle at idle doesnt sound normal unless its a super charger thts jus wht i think
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip
Old April 10th, 2007, 11:49 PM   #29
ujslost's Avatar
If you bump up your idle, you need to check the voltage on the TPS afterwards and make sure you adjust it back to .98 volts. Adjusting the throttle screw will throw the voltage off.
Old June 7th, 2007, 08:33 AM   #30
1993 notch
forgot about this one
but i fixed the whislte
first replace all the upper gaskets intake -plenum tb to egr spacer and so on
then replace any vacuum lines around the intake
then clean all the carbon build up in the tb and egr
and bingo it gone
Old June 7th, 2007, 10:52 PM   #31
ujslost's Avatar
glad you got it fixed
Old June 9th, 2007, 12:49 AM   #32
onewinner is on a distinguished road
HI I have a Holley systemax intake C&L 76mm with Holley 75mm throttle body and trickflow egr delete it does not wisltes.I had a Holley 70mm and a 70mm egr spacer and it wistled at idle and three grand.I think the egr spacer hole was making the wistle
that was my problem on my old set up. deleted the egr and that whistle stopped. got tired of people thinkin i had a supercharger it got in the way of me makin money ;^)
Old June 9th, 2007, 04:42 PM   #33
vfast will become famous soon enough
what intake are you using....if your using a stocker and use a 65mm you will have the whistle as the intake T/B opening needs to be opened up
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old June 9th, 2007, 05:56 PM   #34
Kevin b is on a distinguished road
Go on to BBK web site they tell you why it whistles. Does not hurt anything but sure can be anoying to listen to.
Threads Similar to: Whistling intake HELP
Aftermarket intake vs Cobra intake... Brent Russell 5.0 Mustangs 11 April 27th, 2008 10:35 PM
whistling sound? nedo46 99-04 10 October 12th, 2007 08:24 AM
Whistling noise? The AdMan 2005 - 2010 39 July 12th, 2007 11:17 PM
95' Mustang 5.0 HO intake swap for 93 cobra intake... stang9587 5.0 Mustangs 1 April 3rd, 2007 05:20 AM
Need help using a 5.0 upper intake on a 5.8 lower intake Washington5.0 5.0 Mustangs 4 March 9th, 2007 01:54 AM
