1993 notch
Whistling intake HELP
Hey just got my new 89 lx with a 351 from a ford lightning in her. she runs nice and strong but one problem i have is the idle. 76 mm maf 70 mm bbk tb gt 40 intake and heads 24 lbs injectors.
First the idle goes up and down second there is a whistle coming from the intake that changes pitch with the idle Idle runs about 800 rpm in drive when in park or neutral it goes from 800 - 1300 rpm up and down also i only hear the wisle when its in park or nuetral. im thinking intake leak anyone have this problem before? |
mm got a cold air intake?
American Muscle Against Ricers. Member #6920. |
Same problem here, I called edelbrock and asked them what it was and they said if i can figure it out let them know so they can pass it on.
I will almost bet money it is the BBk throttle body that is whistling.
I have a professional products though and it does the same thing.
1993 notch
yes cold air intake
but sounds like its between runners and intake |
#7 | |
1993 notch
have you tried the gasket between runners and intake. |
1993 notch
maybe it is the throttle body
than what would cause the idle to change |
yes but mine are wet with fuel, ive put 3 sets on it and tried it with black silicon and still get it. Ive torqued it to 20 ftlbs. in sequence everytime but the whistle is still there.
HI I have a Holley systemax intake C&L 76mm with Holley 75mm throttle body and trickflow egr delete it does not wisltes.I had a Holley 70mm and a 70mm egr spacer and it wistled at idle and three grand.I think the egr spacer hole was making the wistle.
i have the same problem and mine is freakin loud..i have had people tell me its a vacum leak tho
I have the Professional Products TB also, it whistles but only when Im gettting on it, never at idle or even less than 3k for that matter. It doesnt bother me, I kinda like it!
Yeah mine whistles too, but not at idle I have a 75mm TB and it only happens when i get on it.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
I have a 70mm BBK throttle body and it whistles just off idle while driving.
everyone thinks i have a huge supercharger
My dodge neon does it everytime the cai slips off the throttle body. My hyundai accent did it because of the cheap air filter it came with. Check those to see if it helps any.
sounds like its not hooked up right.. double check ur vacuum lines at the back of the intake manifold... they might not be on good enough
89 gt 3.73 gears, full exhaust, holley system max2 intake manifold, 70mm throttle body, jet chip |
Everything is hooked up right.
2008 mustang gt
its the egr spacer
Threads Similar to: Whistling intake HELP
| Aftermarket intake vs Cobra intake... | Brent Russell | 5.0 Mustangs | 11 | April 27th, 2008 11:35 PM |
| whistling sound? | nedo46 | 99-04 | 10 | October 12th, 2007 09:24 AM |
| Whistling noise? | The AdMan | 2005 - 2010 | 39 | July 13th, 2007 12:17 AM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 06:20 AM |
| Need help using a 5.0 upper intake on a 5.8 lower intake | Washington5.0 | 5.0 Mustangs | 4 | March 9th, 2007 02:54 AM |
