Clutch slipping already??
Old October 28th, 2010, 11:51 AM   #1
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
So, My friend has a 94 GT vert that we converted from an auto to a t-5. Everything was going great and driving fine for the last three weeks. I suppose he put on about 500 miles or so.
We took our cars to a 1/8th mile track over the weekend. He made 7 passes on street tires and only did a burnout 3 or 4 times. Going home, he called and said his clutch was slipping really bad. We had a hour and a half drive ahead of us. He made it home but his clutch is toast.
He went with a Ram clutch when we did the swap. I've always used Zoom and Centerforce, are Ram's that shitty? I am 100% confident the clutch was installed correctly ( I did it). What do you think?
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old October 28th, 2010, 01:25 PM   #2
95StangMX's Avatar
95 Mustang GT
Either his driving, or bad installation (not adjusted right) or bad out of the box... I don't think even the worst clutch would fry that fast, even with a bad driver.
Old October 28th, 2010, 01:37 PM   #3
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Ram's are not bad at all. My transmission builder recommends them for high HP applications..Something was out of adjustment or he can't drive.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old October 28th, 2010, 03:36 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
possibly not adjusted properly, grease or oil, any number of things. Glazed over friction material...
Ram makes good products tho, from my expierience.
Old October 29th, 2010, 01:26 PM   #5
Digsj7's Avatar
1993 Mustang LX
Hmmm, I suppose it could have been his driving??? I did some more research and it's about 80-20 for people approving of Rams. I sprayed the pressure plate down with carb cleaner before I installed and wiped the clutch down with paper towels to get anything off of it before I installed. We did have a problem with his clutch cable though, he bought a quadrant out of an 96 and a cable for a 94. He drove it like this for a day and it was a bitch to get in gear. Bought a cable for a 96 and everything was cake. I guess that one day of driving it could have done quite a bit of damage....???
Old October 29th, 2010, 01:45 PM   #6
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
sounds like it wasn't adjusted properly so during hard shifts it would burn the clutch. New clutch and a new steeda quadrent and adjust it properly, FTW
Old October 29th, 2010, 02:04 PM   #7
Stangzilla's Avatar
Stangzilla is on a distinguished road
Just an FYI I do not recommend spraying the pressure plate down with carb cleaner. I use brake clean for shit like that.. some carb cleaners leave a residue after they evaporate & Brake clean does not. might not be a big deal but thats what i do
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old October 29th, 2010, 02:13 PM   #8
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
don't you have to pussy clutch it for the first 500 miles on stage 1 clutches and 1000 on stage 2 and 3 clutches?
Old October 29th, 2010, 02:55 PM   #9
1992 Lx
11.39@119.24
broke my king cobra in for maybe 30 miles before goin to the track, looked great when I pulled it off a few months ago
Old October 30th, 2010, 10:55 AM   #10
Digsj7's Avatar
1993 Mustang LX
He ordered a centerfoce...Looks like we're doing it again.
Old October 30th, 2010, 05:07 PM   #11
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
That happened to me. I have the ram clutch too. I took it all apart and it was slipping because there was oil in there from my oil pan gasket leaking
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old October 30th, 2010, 05:11 PM   #12
1992 Mustang LX
13.0 @ 105
That sucks, clutch jobs aren't fun. Especially when you're doing it with a guy who just had shoulder surgery
Old October 30th, 2010, 05:49 PM   #13
91cobra5.0's Avatar
98 Cobra
Ram clutches are pos in my opinion I had a ram stage 1 clutch and it was heavy and started slipping when I sprayed it, went with an act stage 1 and its light grabs hard on motor or nitrous and is rated jigher than the ram, I'm using It with a steeda quick release clutch quadrant, a firewall adjuster and works perfect
Old October 30th, 2010, 05:57 PM   #14
91cobra5.0's Avatar
98 Cobra
Old October 30th, 2010, 06:23 PM   #15
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Maybe you just THINK you know what you are doing?
Maybe you'll find the issue when you change it, as in an oil leak or something. You did put a pilot bearing in the crank when you did the swap right? Not sure if that would cause anything, but that's all I could think of. I used a ram before with good results. Pedal was lighter than whatever was in the car when I got it. Good luck, but I think you'll like the centerforce better. Aftermarket quad adjuster kit FTW though.
Old October 31st, 2010, 12:21 AM   #16
TooSlo86's Avatar
1986 Mustang LX
12.29@111
TooSlo86 is on a distinguished road
I would have to agree with the all of the above, I had nearly the same thing happen w/my new centerforce. While I sat in the staging beams @ 5k rpm the clutch was getting cooked which rendered it useless on the 2-3 and 3-4 shifts in the 1/4 mile. Readjusted the bulkhead adjuster, drove it for a good couple months on the street and last time at the track, no problems from the same clutch. Make sure you get that thing adjusted!
'86 LX, '97 Explorer bottom end & GT40Ps, AFM B-21, TFS v/s, retainers & pushrods, Pro Products upper/lower, 70MM TB, & EGR, 03-04 MAF, BBK 1515's, A9L, Moates QHTuner, FRPP 4.30, HD Z-code 12.29@111mph Mid Michigan Motorplex 4-22-12
Old November 1st, 2010, 09:39 AM   #17
Digsj7's Avatar
1993 Mustang LX
[QUOTE=FastStang91Lx;3266175]Maybe you just THINK you know what you are doing?
He did mention that his rear main was leaking a little, so that could be the issue...
Threads Similar to: Clutch slipping already??
New clutch slipping? Jeff2000GT Modular Mustangs 7 May 3rd, 2010 12:22 PM
how do you know when your clutch is slipping? emgjsdk1 99-04 6 March 28th, 2008 12:34 AM
Clutch Slipping? PowerShiftz02GT 99-04 18 December 2nd, 2007 12:36 PM
clutch slipping? silver99gt 99-04 2 August 4th, 2007 12:19 PM
clutch slipping?? 40thmustanggt 99-04 6 June 20th, 2007 06:12 PM
