Max Hp for stock 1987 5.0 block
Old October 28th, 2010, 08:53 PM   #1
Bettsie is on a distinguished road
Hi everyone,
I have a 19897 GT with a lot of bolt ons and a super charger. The Snow Meth is not working or tuned yet. I have 373 HP and 380 torque to the rear wheels. My MSD 6-al2 packed it in and I ran the last race of the season with it bypassed. I over revved spinning in 2nd gear. I blew the head gaskets.
My question is this, I have to replace the head gaskets, so I thought I would also have
installed TFS-51400010-C01 heads and a Comp Cam 35-556-8 cam. I figure with the meth, heads and cam I would be close if not over 500 rwhp. Can my motor last if I run it 30 passes a year. (or more). I know you can blow up anytime. but wanted some opinions.
Not in my sig, a new 2 stage clutch. Also B&M shifter gone, replaced with Steeda Tri-ax
Thanks in advance and sorry for the long post.
1987 Mustang GT, SQ Trim Vortech Supercharger (10 lbs boost), MacHeaders with 3” Exhaust,Catless ,Dumped: Edelbrook Performer RPM intake, Mass Air Conversion, with Lightning Mass Air Meter, 42 LB injectors, 255 LPH Fuel Pump, MSD Coil /Cap, s. Newer rebuild T-5, r, 3.90 gears Hurst Pistol grip shifter with switch for 2 step, line lock, drive shaft loop and MT ET Street 255 50R16. Subframe connectors, Snow Performance methanol injection stage 2 , waiting for new dyno tune.(372 RWHP)
Old October 28th, 2010, 09:24 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
If your balance is good, and you keep the rpms in check, I think you could get many passes out of it, That being said, you are at the block splitting point at 500rwhp, but many have more and survive more. Call it an average, but that is the going rate. You can always pull some timing out to stay below 500 if it concerns you. Just save the pennies for an aftermarket block since you will be considered by many to be on 'borrowed time'
Old October 28th, 2010, 09:38 PM   #3
I hear you . I was thinking of shifting between 5800 and 6000 nrpm. Hoping to make it last.
Thanks
Old October 28th, 2010, 09:42 PM   #4
1991 Mustang LX 5.0
Hell, if you are running just a stock block/stock rotating assembly, let her buck and if she splits just pick up another, lol. But yeah, you have the right idea imo.
Threads Similar to: Max Hp for stock 1987 5.0 block
Max H.P for a stock 2V engine? Josh2J 99-04 40 July 14th, 2010 11:09 AM
What is the max hp a 3v block can take blown33 2005 - 2010 36 May 8th, 2010 03:37 PM
short block's block vrs block in car stock? adrenaline=lifeline 99-04 7 August 19th, 2008 08:22 AM
max hp for block... delgadog 99-04 14 December 25th, 2006 08:37 PM
