GT40X Heads: Rocker Size and Rod Length?
Old October 28th, 2010, 09:20 PM   #1
'02 4.3L V6 / '95 GT 5.0L
One Bad Sixxx is on a distinguished road
Send a message via AIM to One Bad Sixxx Send a message via Yahoo to One Bad Sixxx
Just bought GT40X aluminum heads for the 306 I am building. With it I am throwing in a TFS1 cam, and upper and lower Cobra intakes. I know I can use the stock lifters, but with a TFS1, would it be bad news bears to go with 1.6 rockers? Or should I go 1.7? And what would the rod length be? Would it stay stock length? Or is it going to change?
http://img.photobucket.com/albums/v289/StreetStangs/V6%20Stroked%20Blown/sig1smc-1.jpg
Old October 28th, 2010, 09:31 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
1.6 rockers are fine. Anytime you change heads, cam, ect.....you have to measure for the correct pushrod length. There can be 20-30 hp loss with the incorrect pushrods.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old October 29th, 2010, 11:19 AM   #3
Would the extra port jobs on the heads, upper and lower intakes make a difference into what size rockers I should get for how much valve lift?
Old October 29th, 2010, 05:35 PM   #4
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Really?? Damn...That's a decent amount on the table just from valvetrain geometry...So do you think I should tear my car apart, measure for pushrods and then order the better size? Cause my heads utilize stock pushrods. My local mustang shop suggested them for that reason: I was on a dirt low budget.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old October 29th, 2010, 06:03 PM   #5
fogged306's Avatar
89 GT
Anytime you change valvetrain parts or heads or even have the block decked, valvetrain geometry needs to be checked, otherwise you could be leaving power on the table.
Old October 30th, 2010, 01:23 AM   #6
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Yes, if you changed something. You're engine has to work a lot harder if the geometry is wrong, not to mention it can cause premature wear.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 30th, 2010, 09:56 AM   #7
88 Mustang lx
marshall88lx is on a distinguished road
I have 1.7 rr on my gt40X's, but yeah def ought to get my valvetrain geometry checked also!
Old October 30th, 2010, 09:59 AM   #8
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
You can run 1.6s, or 1.7s. Whatever you want.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old October 31st, 2010, 11:43 PM   #9
1989 Mustang LX 5.0
slow..help
rauscher89lx is on a distinguished road
this kind of helped me. hahaa thanks! i just scooped up a cobra intake, tfs1 cam, and trying to decide which heads, and then this was the next step. ha
Threads Similar to: GT40X Heads: Rocker Size and Rod Length?
stock block&afr 185 heads what pushrod length????? 89rednotch 5.0 Mustangs 5 April 9th, 2010 04:57 AM
Svo GT40x heads 1989Gt. 5.0 Mustangs 18 June 23rd, 2009 05:22 PM
push rod and rocker size dr.gonzo! 5.0 Mustangs 4 January 2nd, 2009 07:47 PM
Pics of bent push rod & broken rocker arm supermachone The Clubhouse 5 May 18th, 2008 12:02 AM
GT40x cylinder heads what do you guys think about these?? jam77 5.0 Mustangs 1 April 19th, 2007 08:44 PM
