950$ setup.
Old October 28th, 2010, 11:41 PM   #1
1989 Mustang LX 5.0
slow..help
rauscher89lx is on a distinguished road
950$ setup.
gt40heads completely re done
cobra intake, less than 500 miles on it, practically brand new.
tfs 1 camshaft ( brand new )
30lb injectors & 75mm mass air
70mm accufab tb & space ( brand new )
does this sound like it would give me a little bit of power for my money?
Old October 29th, 2010, 12:14 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
I think 30lb injectors are to big with that set up. you may be fine just using your stock 19lb injectors. if not then i would go with 24 lb injectors. But as far as the price of every thing you listed it seems good
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 29th, 2010, 07:16 AM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Good deal. 30's are too big, but if the MAF is calibrated for them, then I guess I'd just use them. Get a tune when you are done with it all, and it will tie it all together with your computer nicely. You should be impressed vs. what you have now.
Old October 29th, 2010, 10:43 AM   #4
30's are too big but if tuned it'll work.. and it'll be a good improvement over stock for sure.
Old October 29th, 2010, 02:55 PM   #5
1992 Lx
11.39@119.24
get it, sell the 30 lbers and maf and use your stock shit
Old October 29th, 2010, 03:24 PM   #6
^^ this
then start saving for a set of 3.73 gears
Old October 29th, 2010, 04:44 PM   #7
1989 LX coupe 5.0L
just putting it out there i am running 30lb injectors with just a small h/c/i setup n/a, works great plus gives you room to grow
Old October 29th, 2010, 05:31 PM   #8
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Like everyone else said...If you find a trade for 24# injectors/MAF for that setup just do that. But otherwise, that will make good power over stock. Won't feel like the same car.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old October 29th, 2010, 07:49 PM   #9
1989 Mustang LX 5.0
slow..help
Originally Posted by flyin ryan View Post
^^ this
haha, i have 373s =)
Old October 29th, 2010, 07:50 PM   #10
1989 Mustang LX 5.0
slow..help
thanks!
Old October 29th, 2010, 08:29 PM   #11
1991 Mustang LX 5.0
Just cuz one dude is running 30's with his 'small' setup doesn't mean that it's what YOU need. If you insist on using the 30's, get a tune.
I'm running the Track Heat intake, Stage 2 cam, and TF 185cnc's with 30's. That's way more air movement than what you got, just for an example.
Old October 30th, 2010, 12:43 AM   #12
ryans88gt's Avatar
30 lb injectors work just fine on a mild setup as long as the maf is calibrated or the computer is tuned. Even with just a calibrated maf they'll work fine.
Old October 30th, 2010, 01:00 AM   #13
1989 Mustang LX 5.0
slow..help
the maf is calibrated to the injectors... if i cant sell them by the time i puzzle everything together, there going on with out a doubt. and i definitely will be sure to get a tune regardless! the only reason why im thinking about not getting rid of them is because there is definitely a turbo or supercharger in the near future! well at least, maybe sometime over winter. but first i gotta get used to the ride once its complete with this setup
Old October 31st, 2010, 11:31 AM   #14
1989 Mustang LX 5.0
slow..help
just scooped up all of these parts, except i didn't pickup the heads yet, still up in the air if i want to pickup my buddys gt40s for 400.. otherwise, need some info on whether or noti should change my rockers and lifters while i already have everything taken apart?
whats the difference between stamped and roller rockers?
and which ones would be good, compatible with tfs1 camshaft, cobra intake, and gt40 heads? any suggestions.
Old October 31st, 2010, 12:18 PM   #15
e3sean's Avatar
1988 lx
9.68@142
keep the 30" get it chipped/tuned and you will be good to go. then yor injectors will be working 1/2 as hard to do the same job.
<font size=4><b>MILITARY CREW
Old October 31st, 2010, 12:31 PM   #16
91cobra5.0's Avatar
98 Cobra
if you havent bought the heads then dont yet! try and hold out for a used set of aluminums i have the gt40s and while i like it a lot i wish i would have just saved the 400$ more while i was already half way there.
and roller rockers have a roller tip that moves smother on the spring and stamped is what we have stock, its just a stamped metal rocker arm, the rollers allow for faster revs and a few hp
Old October 31st, 2010, 03:00 PM   #17
1989 Mustang LX 5.0
slow..help
sounds good thanks!
Old October 31st, 2010, 03:04 PM   #18
1989 Mustang LX 5.0
slow..help
thanks! i'll look into a set of rockers while im at it.. and what should i do? i have everything but the heads and the rockers, and i need to have this purchased by wednesday for install. i dont want to have to put it all on, and then come back and do the heads..
also,what about pushrods? do i need them?
Old October 31st, 2010, 04:27 PM   #19
1991 Mustang LX 5.0
You should always measure for pushrod length, and unless the gt40's have been converted from pedestal to stud, you would need a different type of rocker for aftermarket heads. If you need this by wed, just get the GT40's and live with what you have for a while. You really need to have a TOTAL game plan before you jump into modding your motor. You need to know what you want out of it. If you just go that route, then you will have more power and that will allow you to build up the rest of the car suspension wise and such. Take your time when it comes to buying aftermarket heads. Deals come up, and if you keep an open eye, you may scoop up a better deal down the line. But depending what you want out of your motor will dictate how much $ you will need to save later. Alot of rambling, but hopefully you get the idea.
Old October 31st, 2010, 08:17 PM   #20
1989 Mustang LX 5.0
slow..help
maybe i'll take a little more time to look in the long run picture and get everything figured out first. thanks
Threads Similar to: 950$ setup.
Fuel pump setup for 500RWHP setup bobz18711 99-04 34 September 19th, 2010 11:52 PM
18" fr500 black wheels with 255/45/18 front and 295/35/18 rear almost brand new $950 mustanggt_03 99-04 7 February 13th, 2009 04:02 PM
mmr 5.4 950 shortblock....??? 94pacecarSVT 99-04 8 September 7th, 2008 09:44 PM
Classic body taillight setup vs. s197 setup rockybalboa Visual 1 May 22nd, 2008 12:08 PM
