Normal temp reading?
Old October 29th, 2010, 08:41 PM   #1
copracr is on a distinguished road
I just put a new radiator, cap, and 195 degree t-stat in and was wondering what the factory gauge should read.
The gauge says 130 at the bottom and 270 at the top so the middle should be 200 (and about where my gauge should run if its heating up properly), but i'm running quite a bit under that. I'm guessing the factory gauge is about as sh1tty as most 20 y/o factory guages are and its just plain wrong.
As a side note, i took out a 192 degree t-stat and it ran at the same level with that one too. I was thinking someone had put a lower temp one in, but i guess not.
**edit** I tried to attach a pic but that doesnt want to work. But the gauge reads a few mm's above the 3rd bar
Old October 29th, 2010, 09:04 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Factory gauge is shit, you would need to hook up a mechanical gauge to see what the temp really is. Mine is way off, it starts right above the 130 for me. I just use the 'hope it's good' method for now. LOL
Old October 29th, 2010, 11:23 PM   #3
WhiteMamba's Avatar
88 Notch
WhiteMamba is on a distinguished road
if it aint smoking, your running fine.
88 Notchy
306 with 70mm Turbo
510 RWHP on 10lbs
K thnx
Can we chat?
Old October 29th, 2010, 11:26 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I think it is 210; and like they said, don't trust your stock gauge.
Threads Similar to: Normal temp reading?
rough idle / no temp reading / high pitch whine after intake manifold replacement brianallman 96-98 1 August 20th, 2010 02:16 AM
Engine Running Hot but Temps Are Reading Normal? Pittbull 99-04 51 February 4th, 2010 09:27 AM
engine temp and oil temp off Reset? warrior86 V6 Mustangs 3 November 29th, 2008 01:48 PM
whats the normal temp gauge reading? 03snakeminated 4V / SVT 4 September 2nd, 2008 11:43 AM
what temp is normal on a stock 89 gt? YNOT 5.0 Mustangs 11 March 20th, 2007 03:12 PM
