Whats Next Step to Speed
I have a 1992 Mustang GT with dyno max exhaut, headers, X pipe, mac intake, Corbra Upper and Lower intake manifold. What is the next step for increase horshpower. I was thinking about cams or gears. What would work good for my car and how much does it usally cost.
How much do you have to spend?
1983 GT
UNKNOWN
cam swap would probably be cheaper than a gear swap overall.....but it also depends on if you are doing it yourself also. most places charge anywhere fron $275-$400 to put a set of gears in as for swapping a cam i have no idea on labor cost for that. i could almost guarantee you would see a bigger improvement on your timeslips with a gear swap than with a cam swap though. also depends on what kind of tranny you have. if you do a bigger cam then you might have to get a stall convertor if you have an automatic. as for the gears anywhere from 3.73 to a 4.11 would show a big difference
1983 FOX BODY-LIL SOMTHIN IN PROGRESS |
You need to let your pony breathe. Cam is kinda useless with stock heads. Heads +Cam = Good.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
'88 LX body '91 GT D/T
8.7 in the 1/8th
Nitrous! FTW!! Cheap and easy... I am not an advocator of nitrous, but it is a very big bang for the buck.
Gears will most def show the greatest time improvement, like 83five0 said, but an H/C swap will benefit in the long run, just like Haggis said, especially if you plan a major poweradded. Ie; Supercharger or Turbo... Darrell brought up a good point too; how much $ ya got?
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
fast, cheep, reliable - pick two
+1 on all of the above. just think what you are going to use the car for. drag, race, daily driver? |
8.7 in the 1/8th
Question: are you wanting control and speed or just balls out, god I hope my car goes straight, power?
If you are planning on actually hooking up, do your suspension.
What do you use the car for? What are your priorities?
Um, guys, the next time you feel like posting to this thread, hold a sea shell up to your ear. You get the same effect, the thread is over a year old and the topic creator hasn't posted anywhere on MM in just as much time.
#10 | |
1965 Mustang Fastback
I'm a good boy now. [COLOR=red][B]slow car club - crew member 7 of 9 [COLOR=White]Mood: Cool :cool: [/COLOR][/B] [/COLOR] |
Threads Similar to: Whats Next Step to Speed
| Step By Step Sound System Installation 00-04 Mustang GT | mixedbreed02gt | Audio/Video | 5 | July 26th, 2010 09:00 AM |
| The Next Step.... | Kosinski | 96-98 | 8 | September 6th, 2007 08:24 PM |
| whats the next step | UNOH98stang | 96-98 | 19 | August 9th, 2007 03:48 PM |
| WHats the best next step on a clutch upgrade! stage 2? | Stang-kid | V6 Mustangs | 9 | January 12th, 2007 09:42 PM |
| V6 - Bolt On's - Step By Step? | CyberPrey | V6 Mustangs | 5 | October 30th, 2006 11:39 AM |
