87 GT
Looking for opinions for a 418 stroker
Long time reader first time posting! Noob here from Bedford Indiana looking for some opinions. I'm building a 418 stroker for my 87, I have the 69 351 windsor block, c-3 nascar yates heads and intake ported to the max on both. I want to be able to drive it on the street, but yet be fast enough to out run most at the track, and run on pump gas. Inverted pistons to keep compression down? I am thinking my heads are around 50 cc's with 2.150 x 160's. I have the turbo coupe t-5 with 8.8 and 411's. Opinions greatly appreciated! Here is the heads and intake,
1969 Mustang Mach 1
6.824@101.61
So are you just wondering about compression? N/A motor?
Static compression isn't as critical if you have the proper camshaft. You would be money well spent on a custom cam.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
87 GT
Yes and carb size, I also need to know what rockers to run on the heads, 1.6's, and what kind of horse power am I looking at?
1969 Mustang Mach 1
6.824@101.61
Any idea what those heads flow? I don't know much about them.
1991 Mustang LX 5.0
That T5 will be toast!!!
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
87 GT
I can't remember what the guy said about flow. They are ported to the max and when you look down into the intake, its completely open. I forgot to mention,, all this is going on or in a 1969 351 windsor.
87 GT
1969 Mustang Mach 1
6.824@101.61
No glide if you're driving on the street. A C4 can be built plenty strong and weighs considerably less than a C6, so I'd say C4.
To answer anything else, you really need to know what the heads flow. If you want the best of track times, and drivability, the best way to go is to get a custom cam from a reputable place, and then call some place like Pro-Systems and get a custom carb. You're probably going to be looking in the 850 CFM range for the carb.
#9 | |
87 GT
you either need an adapter or run a 4500 carb(dominator) Dominators can be a pain to get to run like a normal car on the street. More of the wide open or idle carb. They make adapters for this, 4500 to 4150 carb flanges
where did you come about these parts too?
87 GT
Threads Similar to: Looking for opinions for a 418 stroker
| 331 stroker or 306 stroker? S/C or N/A | 91Mustang GT | 5.0 Mustangs | 6 | December 8th, 2010 11:00 AM |
| opinions about this look on my car...please vote....or post your opinions.. | turbot4 | 99-04 | 79 | July 22nd, 2009 07:31 AM |
| To Stroker or Not to Stroker? That is the Question! | 87StangLX | General Tech | 13 | October 20th, 2007 10:46 AM |
| Heads for 418 c.i | 89hatchback | 5.0 Mustangs | 15 | February 27th, 2007 04:43 PM |
| stroker? | SWEET2KSTANG | 99-04 | 11 | December 2nd, 2006 09:02 PM |
