Tie-Rod problems
Old November 1st, 2010, 05:45 PM   #1
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
Tie-Rod problems
Hey guys,quick question about my tie-rods.When i grab my rim at the 3&9 o'clock position,the wheel moves left to right probably 1/4 inch or more.Now which is it the inner or outer tie-rod end?Also how hard ar ethey to replace? Thanks
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Old November 1st, 2010, 07:04 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
Could be either inner or outer or both, lift it up, support it with jack stands and get under and wiggle and see where the slop is. A 1/4 inch is pretty bad and should be easy to track down the problem, with it that bad I'd guess at least the inner is bad. You can grab the tie rod itself and wiggle to narrow it down too. Only requires a few wrenches, and a large adjustable for the inners, and a tie rod separator or a plain old 2 or 3 prong gear puller and some wd40 for the outers. Requires an alignment when finished. I recently had a bad inner and just replaced both sides inner and outers in about 2 hours total. The parts arent expensive so why not.
Old November 1st, 2010, 07:14 PM   #3
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
Yeah ive never replaced them before.Gotta do it myself,no loot.Shop around the corners got a special on alignments for 50 bucks.You think autozone rents that Tie-Rod seperator?
Old November 1st, 2010, 07:31 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
They do loan out a tie rod separator, I think they have house brand (Duralast) inners and outers for about $20 each too. I paid a little more for the Moog ones on my Mustang but I've used the Duralast ones on a few of my other cars with no problem. It is not a hard job at all and once you do the first side, the other will be a lot easier. You should mark the threads so you can get it close for your drive to the alignment place, if you swap out an inner and an outer, you'll have to eye ball the alignment but if the shop is close by, you'll be good.
Old November 1st, 2010, 07:42 PM   #5
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
Thanks for the info.
Threads Similar to: Tie-Rod problems
Tie rod trent2590 99-04 16 March 11th, 2010 08:21 AM
Does anybody know the inner tie rod to inner tie rod lenght on a mustang? Volvo Heretic Modular Mustangs 0 August 28th, 2009 04:36 PM
Anybody know the inner tie rod to tie rod widths of Mustang racks Volvo Heretic All Other Vehicles 1 August 28th, 2009 12:05 PM
tie rod ? 00redgt 99-04 5 March 29th, 2009 10:07 PM
tie rod zinc02GT 99-04 3 May 12th, 2008 01:23 AM
