Throttle body Questions
Old November 2nd, 2010, 04:31 PM   #1
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
I have a pretty much stock motor, except a 2.5 inch exhaust from stock intake manifolds back. The question I have is that I have been looking to buy a bbk 70mm throttle body and would like to know if I will benefit at all from putting a bigger throttle body on without doing any other work to it at the moment. I have heard some people say it will do more harm than good and I have heard other saying you would gain up to like 10 hp but im assuming that's with supporting air flow mods such as biger ports for upper and lower intake manifold, that sort of thing. So I want ur guys input on this. I need a new throttle body anyways because the seals inside are bad and its contributing to my vaccum leak. Even if it doesn't help out any I will be okay with that as long as it doesn't negatively effect my performance. It is nice and shiny though..lol, thanks for the help
Old November 2nd, 2010, 04:48 PM   #2
sj408 will become famous soon enough
dont see why anyone claims it would negatively affect you, it will just help your 5.0 breath better. i say go for it! especially if your current throttle body is leaky.
your not gonna gain like ten hp.... im sure hardly even 2 but you definetly will feel a better throttle response through all rpms.
Old November 2nd, 2010, 04:51 PM   #3
lilspanky9119's Avatar
98 Mustang GT 4.6L v8
lilspanky9119 is on a distinguished road
An after market throttle body will improve throttle response, especially after some other throttle response mods, such as a CAI, and upper plenum. Like ^ said, you might see a few HP, but not 10.
3:73 gears, Steed tri-ax, Mac o/r pro chamber mid pipe, w/ 2 chamber 2.5” Flowmasters,C&L upper plenum,
Livernois PI intake swap kit, Steeda timing adjuster 16', FR 70mm throttle body, FR aluminum driveshaft, Lowering springs, BBK CAI
Old November 2nd, 2010, 06:09 PM   #4
1995 Mustang GT
ok, sweet...sounds good to me
Old November 2nd, 2010, 07:46 PM   #5
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Make sure you port match your intake opening to the TB or the 'lip' will cause turbulence and therefore, could hurt you.
Old November 2nd, 2010, 09:36 PM   #6
1995 Mustang GT
lol, are you serious bro? could you elaborate on that a little more? ^
Old November 2nd, 2010, 09:41 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
port match your TB to you intake port....70mm TB =70mm intake opening. Also you may need to upgrade to a 70mm EGR
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 2nd, 2010, 10:09 PM   #8
1991 Mustang LX 5.0
Yeah, with a die grinder it's pretty easy.
Old November 2nd, 2010, 10:52 PM   #9
1995 Mustang GT
damn that seems like something that i dont have the extra time to do right now, lol, figured it was just gonna be a slap on and go... :/
Old November 3rd, 2010, 01:39 AM   #10
ryanw's Avatar
if you just want to slap and go then go on ebay and get a stock one for your car. and you will save money. but if your going to do the porting id set aside a day to do it. pull your upper plenum,remove TB and EGR, port it to 70mm, clean out all the metal inside the intake. reinstall intake with new gasket,install new tb and egr with new gaskets. dont forget to plug all your vacuum lines back in
255 fuel pump,
3:27 gears
Old November 3rd, 2010, 02:30 AM   #11
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Its not that hard broski. Just put it on hit it with the die grinder like mentioned and wala!
Old November 3rd, 2010, 12:11 PM   #12
1990 5.0 LX SSP
Colt.45 is an unknown quantity at this point
Since you are still stock and you want a quick fix.Have you considered a 65mm? The heads are the biggest restriction on a 5.0.For the time being a good 65mm should be plenty.And will bolt right up to your intake.
Just something to think about.
Old November 3rd, 2010, 12:19 PM   #13
1995 Mustang GT
i would have the intake ported but i have never done something like that before and i am a full time accounting major if you can picture that, lol..so whatever im looking to do has to be fairly simple and pretty much bolt on. But i did look on ebay and there isnt any stockers for my car right now, there is one but it says $100 OBO so yeah i was like f that. but the 65mm is interesting i would consider grabbing one of those if i could find one for a good price, anyone have one or know where i can get one, im lookin to buy this thursday or friday if possible
Old November 3rd, 2010, 12:23 PM   #14
1995 Mustang GT
well i did find one in good shape but i wanna see if i can talk him down a bit, price is a little high for me
Throttle Body Ford Mustang GT 94 95 BBK 65mm 1522 used: eBay Motors (item 280580882388 end time Nov-25-10 18:19:19 PST)
and this one will be a direct bolt on correct?
Old November 3rd, 2010, 01:19 PM   #15
1990 5.0 LX SSP
You will need a 65mm egr plate for your tb to bolt to.Or at least I did on my "90".Never had a 94 but I don't think they are much diff.except for the elbow. Someone please correct me if I'm wrong.Good luck.
Old November 3rd, 2010, 02:03 PM   #16
1992 Lx
11.39@119.24
save the money
Threads Similar to: Throttle body Questions
Throttle Body Questions southfour! 99-04 4 February 23rd, 2010 07:37 PM
throttle body, mass, intake plenium questions, i need answers... turbot4 99-04 29 February 1st, 2009 02:21 PM
Throttle body and ram air questions.... 88dragstang 5.0 Mustangs 9 January 5th, 2009 12:13 AM
throttle body/plenum questions 03SuperchargedGT 99-04 22 August 20th, 2008 02:30 PM
Throttle body, IAC, TPS, Mass air questions for my 347. problemCOBRA94 5.0 Mustangs 8 January 18th, 2008 05:33 PM
