1990 Mustang 5.0 LX
1990 5.0 lx CHARGING and STARTING ISSUES
I bought my 1990 5.0 lx a little over 2 years ago the car had some engine mods done by the previous owner exchaust headers he put a MSD in and a cold air intake i had the car maybe 6 months and than the issues the car would not and still will not start when the temp is over 180 even after i replaced the starter which i knew was going bad,, i finally replaced thinking all my high temp starting promblems.. NOPE so i thought maybe alterntor .. so i took it out had it tested it was bad so i bought a brand new one not a rebuild.. put it in and still not charging brand new battery brand new starter solnoid iam reading 6 to 8v at the solnoid i have checked a my connections and still nothing the battery in located in the trunk but iam still not getting any reading over 8v at the solnoid
PLEASE HELP iam at wits end the car sounds great it has balls but iam only able to go a few miles from the house and i can not turn it off til i get in back into the garage .. IT SUCKS |
1991 Ford Mustang GT
Do you have a good ground ? Also what size gage wier are you using for positive ? If your running the battery in the back you need a big wier
1990 Mustang 5.0 LX
yes it has a good ground actually grounded in several locations i believe the size of the wire is 4 gauge i didnt install the wire i bought the car that way but i did check all the grounds
I could be wrong but i thought i saw on another thread that you should be running a 2 or a 0 gage wier i cant remember wich though.
1990 Mustang 5.0 LX
yea thats what i have been told but like i said iam not getting a thing higher than 8v at the solenoid so i figure the size of the wire going back to the battery at this point shouldnt matter
check power at the alt and see what you have. Ive gotton bad alt that were new right out of the box
1990 Mustang 5.0 LX
on which wire should i be checking i know this probably sounds like a stupid question but iam no mechanic i have never had this problem with any vechicle i have had
1990 Mustang 5.0 LX
the reason why iam asking is because this alternator has the push connector on it with 2 black/orange wires and a single white wire
http://www.veryuseful.com/mustang/te...nks-ign-ac.gif it looks like its the black/orage wier. maybe you have a bad fues link
Threads Similar to: 1990 5.0 lx CHARGING and STARTING ISSUES
| 86 GT 5.0 Starter, charging issues? | Serpent | 5.0 Mustangs | 10 | June 23rd, 2010 09:27 PM |
| Charging Issues | FOX347 | 5.0 Mustangs | 1 | April 7th, 2010 05:13 PM |
| charging issues...need help | feedmeurskinnyppl | 5.0 Mustangs | 3 | February 1st, 2010 07:37 AM |
| charging/starting system question | chaosstangman | 5.0 Mustangs | 2 | December 4th, 2009 12:11 AM |
| 1990 Mustang 2.3 Charging Problems | JKDZ28 | 2.3 Mustangs | 1 | January 22nd, 2009 08:53 PM |
