1988 Mustang GT
13.5@102
BANG no more engine (help!)
shifted into second gear @about 2000 rpms and it looks like my fucking crank broke in half. the end of the crank is out of the block thru the timing cover ripped the timing chain all to shit etc.. no holes anywhere else.. as much as i can see, by the position of the the crank it prolly took a few rods with it. no warning at all car has been running great. pulls hard no knocks or any noise whatsoever. killer fuel economy for what it is.
so my short block is toast.. heads maybe even what else? i dont know these cars well enough to know if the damn thing fucked up my input shaft on the tranny or what i should be expecting to replace. im coming from turbo 4cyl dodge land thinking i should have stayed. im hoping somebody can shed some light on what i should expect to replace. im looking for options on replacing the broken shit. heads were ported stock junk. dunno about my cam it was just an e303 way the crank is sitting halfway out the motor its prolly bent. so its looking like a tall block.. ideas? sourced a couple 88k-100k explorer engines for cheap (450$).. what years will fit?? or should i dump coins and buy a reman tall block.. all i can find tho is frpp with junk aluminum x heads. thank in advance luckily i hit the store for beer before it broke so i can drown my sorrows and let my wallet know its about to be sacrificed. clue me in thanks in advance. |
sounds like your block split which is a common problem, altho usually takes more hp than what you're pushing if you're trapping 107. an explorer long block would work, then you'll have gt40 heads/intake. just buy a good cam to replace the stocker and your e303 and you'll be good to go. also it shouldn't of affected your input shaft if it came outwords to the front, might be looking at a new clutch/flywheel tho.
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
1988 Mustang GT
13.5@102
yeah car is a sled. my dodge runs a 12.5 with 4 less cylinders. i bought this car just to tool around and i have never beat on it. never even spun the tires.
i sourced a 2000 explorer engine for cheap. are there things i need to change to make it fit? thinking flywheel is def toast prolly the disk pissed brand new king cobra. gt40 intake better than the cobra which i have on there now?? i have a holley systemax i just bought so id prolly use that. i have a 75mm Tb tho.. i dunno if it fits the holley. |
#4 | |
1988 Mustang GT
13.5@102
arent the newer 5.0's not running forged components? hypereutectic or some shit?
what cam would u recommend?? who is this woody fellow i have heard about on here that build short block?? |
woody owns a company called ford strokers and build lots and lots of motors. my only negative thing about him(if you wanna call it a negative) is that it takes some time to get a motor from him, prolly 4 months or so now from the time you place the order to the time you get it.
the comp extreme energy cams are good ones as far as off the shelf cams go, i myself have a camshaft innovations custom cam which would be the best way to go, but they are a little more expensive. and also you may be right, it might have the hyper pistons in it, but for most occasions it will be perfectly strong enough for an h/c/i motor.
1988 Mustang GT
13.5@102
looking more for reliability than a race car.. this car has bbk longtubes and flowmasters alum driveshaft 3:73 locker. fine for a dd with a little sac. all i need
t5 was rebuild with hardened input shaft and that steel retainer bearing, made no noise 88k 2000 exploror 5.0 for 450 bux a decent deal? cam it and port the heads? |
yeah that sounds pretty good to me. should be a nice little dd.
1988 Mustang GT
13.5@102
thanks bro i appreciate the input
01
JB weld will solve all your problems with that crank.
1969 Mustang Mach 1
6.824@101.61
Woody is more like 6 months out now......sigh........
My car may never run again
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
89 GT
How much money are you willing to spend? I can get shortblocks around here for $300 all day. Find one cheap and go for some used trickflows and get the right cam for those heads and a systemax and you'll be better than a 12.5 and dd it no problem.
1988 Mustang GT
13.5@102
pissed. drunk too fuckin car
I just found a 2000 explorer motor for like 450 has 88k on it
Its local. Figuring its my easiest way out at this Point 300$ used shortblocks? Yards Im lookin around tho. I havent seen too many tf heads used |
if you're interested in buying some better heads and what not then check out corral.net, they have a huge classified section. i'd go ahead and buy the explorer unit for 450, then if you wanna swap heads you can prolly sell the explorer heads you get for around 200.
1993 Mustang LX
my dog runs faster...
Hypereutectic's are only on 93 fox's.
![]() MM+Cleavage Club Member #19
1988 Mustang GT
13.5@102
so a 2000 5.0 would have forged internals??
1992 Lx
11.39@119.24
people get stuck on forged internals too dam much
1988 Mustang GT
13.5@102
where i came from forged is everything.. i run 27 psi thru an old school 2.2 4 cyl and if the pistons werent forged the rods werent forged and the crank wasnt forged it breaks. figured it was an applicable question seeing at some point the car i run will get a hairdryer.
1982 GT t-top
no proof of purchase
the hyper internals will hold up just as long as the block with a good tune...detonation will kill em
1991 Mustang LX 5.0
Stock block is only good for about 550-600 depending who you ask and what day it is. So if you play on going big someday, you need to look into an aftermarket block too. The only FOX mustang that came with hypers is the 93 and same thereafter. Explorer motor will have hyper's too.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: BANG no more engine (help!)
| Bang for my buck?? | TrueBlue756 | 2005 - 2010 | 27 | September 21st, 2010 01:23 PM |
| Weird bang from engine after longish cruise | pear0119 | 2005 - 2010 | 19 | July 19th, 2009 10:23 AM |
| bang for buck? | kennyGT | 99-04 | 5 | January 13th, 2008 10:33 PM |
| Just a joke bang bang | WAR-PARTY | The Clubhouse | 12 | April 5th, 2007 01:46 PM |
