what gauges recommended with adding charger
Old November 2nd, 2010, 11:36 PM   #1
1990 Mustang GT
rocket is on a distinguished road
Adding vortec, is boost and fuel/air gauge wideband recommended??
Old November 3rd, 2010, 08:12 AM   #2
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
boost is a must, i recommend a wideband if you pushing the limits of your fuel system.
Old November 3rd, 2010, 10:46 AM   #3
1990 Mustang GT
Ok, thats what I was thinking, but wasnt sure about the wideband vs something else that might be useful.
Old November 3rd, 2010, 05:42 PM   #4
1988 Mustang GT
13.5@102
PureEnergi is on a distinguished road
Egt gauge is popular also.. also run good quality O2 sensors. most widebands use a newer style bosch
wideband uses far better electronics and is far more sensitive than a narrow band item. thus they respond faster to changes in air/fuel therefore very accurate. if you run 16+ (3bar+) psi this is a def needed item.
Old November 3rd, 2010, 09:56 PM   #5
1987 GT
13.19 @ 107.02 (street tires)
chrisbmx is on a distinguished road
Definitely run a wideband air fuel. You will want to know where your air/fuel ratio is for sure. Unless of course you're looking for a reason to do an engine rebuild. I have a Vortech V3 only running 5# and have a wideband, fuel pressure, and vac/boost gauge. I'm happy with them. Just my 2 cents.
Old November 4th, 2010, 12:03 PM   #6
1990 Mustang GT
thanks. went with boost/vac and wideband.
Old November 4th, 2010, 12:05 PM   #7
baine21225's Avatar
Those are the only two you really need, i did a write up on a boost gauge install if you dont know how to, and if you have any questions about the wideband shoot me a pm. the only other gauge i may think about is a oil pressure gauge.
Threads Similar to: what gauges recommended with adding charger
Adding gauges! RZNCAIN 2005 - 2010 15 July 23rd, 2010 12:35 AM
Super Charger or Turbo Charger 20cooper08 V6 Mustangs 22 September 1st, 2009 10:17 AM
Turbo Charger or Super Charger? lil_soldier_boy 2005 - 2010 V6 32 June 21st, 2009 02:59 PM
Super Charger, Turbo Charger Effects? Gtwrestler Modular Mustangs 15 June 9th, 2009 07:02 PM
