LinkBack (1) | Thread Tools |
#1
98 Cobra
job of wire on ignition lock
there is 1 wire leading off of the ignition cylinder lock (the key piece), were does that wire go to and what is its job??
1992 Lx
11.39@119.24
looked like a ground to mee
Moderator
If it's anything like the new edges it grounds out when you insert your key and makes the chiming sound when you've get the keys in the ignition and the door open it's something to remind you not to leave your keys in the car.
![]() ![]() BUILD 2 IN PROGRESS |
1990 mustang gt
Any pic?
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
98 Cobra
this is the part:
Ignition Lock (Cylinder & Keys) | 1991 Ford Mustang 8 Cylinders E 5.0L FI HP | AutoZone.com ill try and get a picture later. do the locks themselves ever go bad? |
98 Cobra
if i added a wire to bypass all the stuff in between the ignition switch and the ignition coil in the engine bay to get the starter to turn, would this work?
91 mustang gt/90 7up vert
what are you trying to do? it looks to me like you just made it so the car will never turn off. that wire would keep the eec relay hot all the time how you have it in the schematic. that is the run circuit, not the start circuit
1990 mustang gt
On my car the starter wire at the switch was white/pink. But yea you can run the starter wire from the ignition switch straight to the starter solenoid to the thin red/blue wire(that's the color on mine).
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/190624-job-wire-ignition-lock.html
| Thread job of wire on ignition lock | Forums at Modded Mustangs | BoardReader | This thread | Refback | August 1st, 2011 02:39 PM | |
Threads Similar to: job of wire on ignition lock
| Ignition harness wire colors for a S197 GT? | asiansensation78 | 2005 - 2010 | 5 | August 14th, 2010 03:44 PM |
| 1998 ignition lock cylinder | BBMUSTANG | V6 Mustangs | 0 | July 25th, 2010 01:51 PM |
| Ground Wire Gauge.. Same Size as Power Wire or No? | warrior86 | Audio/Video | 4 | January 30th, 2010 06:41 PM |
| wire spacers and wire lube | v6must742 | V6 Mustangs | 0 | November 18th, 2009 09:23 PM |
| Ignition Key Lock | cali 5.0 | 5.0 Mustangs | 8 | September 5th, 2006 01:31 PM |
