#21 |
2001 Mustang GT
13.8@101.58mph!
Thanks for all the info guys
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
#22 |
Priest of the Car Gods
Hrm.
It's my understanding that the biggest restriction on the 5.0s after the stock exhaust is the heads. I was under the impression that you're just wasting money to do a bunch of bolt-ons until you had better heads swapped on, even if they were just some junkyard iron GT40s off of an Explorer.
#23 |
2001 Mustang GT
13.8@101.58mph!
Thats the thing.I can barely afford a h/c/i/ combo plus install and supporting mods or,get a cai,pulleys,headers,o/r h-pipe,70mm TB,EGR,Sub frame connectors,strut tower brace,Stall conv,4.10's,and drag radials.I would like to get all the supporting mods first,and save for the h/c/i..What would you do?
#24 |
I think what jumped out at me was just the TB. I wouldn't do that 'til you have better flowing heads. Other than that, I totally agree - traction before power.
I was about to say don't waste your time with the STB, but then I saw you have a 'vert, so I'll say when you get a STB, just make sure to get one that's triangulated to the firewall.
#25 |
2001 Mustang GT
13.8@101.58mph!
Yeah gotta get the chassis in line first,cause this thing likes to flex
#26 | |
Gluck and keep us updated!
Dart Iron Eagle block & Pro 1 heads DSS 347 80lb injectors D1-SC blueovalindustries headers BBK o/r X Flowmaster cat-back 3.73 gears |
#27 |
99 Cobra - 92 LX - 90 LX
I would go 70mm
Question: What does single life get you? Answer:
#28 |
95 Mustang GT
I would work your suspension, and buy HCI and save up for the supporting mods and labor and do it all at once, go ahead and do exhaust and gears with the suspension if you have the money now..
![]() People should think about boarding up their glass house before starting a rock fight! |
#29 |
2001 Mustang GT
13.8@101.58mph!
What are the typical HP gains from these bolt on mods-Stuff like pulleys, headers,o/r H-0pipe,CAI,70mm TB,Timing @14*.Also what are the typical gains from doing the H/C/I combo? What would be the avereage labor cost to install a Head,cam,and intake combo?
#30 |
95 Mustang GT
Pullies headers CAI TB are basically supporting mods, don't expect to pick up much from them as far as HP or seat of the pants feel, Your best bet as far as feeling it will be gears, and then HCI, all of the other stuff you mentioned will help after you do the top end.
As far as the "typical gains" that all depends on what Heads, cam, and intakes you decide to go with and how well you match your setup. You should focus more on 1/4 times or how it feels to you than HP anyways. You need to decide how much you are going to spend on the combo, and go from there as far as how well it will run and how fast. Labor cost vary depending on where you live and the mechanic I have no idea what a job like that would cost having a mechanic do it, I have always done my own. I have seen friends pay 1200-1500 for a head gasket which to me is fucking outrageous, but I guess it depends on location and mechanic.
#31 |
2001 Mustang GT
13.8@101.58mph!
Well its like this,ill have 2grand to play with.So im debating the best way to go.With that 2G's i have to get full-lenght SFC's,and some 4.10's installed.I just dont think ill have enough loot for the h/c/i combo and TB,and a CAI.And who knows what else.I can install all the bolt ons myself so thatll save me alot of loot.
#32 |
don't even worry about upgrading your throttle body if your keeping your stock intake.. the lower stock intake has pencil sized ports so porting your tb opening and buying a larger tb isn't going to net you next to nothing.
wait on the tb until you throw another manifold at the car.. focus on the gears, subframes and shit first |
#33 |
2001 Mustang GT
13.8@101.58mph!
Cool that will save me some loot for other shit.That'll pay for some new balljoints.When i do upgrade the intake and heads,it will most likely be a Explorer or Cobra unit.Will i need to upgrade to 24LBS injectors and a larger fuel pump?
#34 |
1991 Mustang LX 5.0
Injectors when you change to better flowing heads. Stock explorer heads 19's are usually still fine. fighly ported explorer's, Afr 165, 185, and TF 170's 24's will usually do it. Bigger than those, 30's might be what you need. Obviously the cam choice comes into play too, but that's just a good base to go on. There are many charts you can use that have injector hp ratings. I'm not on my own pc at the moment otherwise I would pull one out of my 'favorites' and post it for you. As long as you are realistic about the power you will be making (not going by manufacturer claims) you will get the right injector for your situation.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#35 |
You can change out your upper/lower intake to an explorer or cobra and get some gains.. but after you upgrade there (ditch the stock lower intake) then next bottle kneck of power is the stock e7 heads which on a budget you should be pulling gt40 iron heads off an explorer/mountaineer.
You don't have to go with a cam/heads combo.. you could save up for a used vortech a trim, sc trim or s trim and bolt that bitch on.. pickup a used set of injectors and matching meter and rock out with your cock out |
#36 | |
1989 Mustang GT 5.0
uh i lined up TB to upper and looked into it, and the 70mm TB matches perfect....i wonder if trickflow made different models of the track heat?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#37 |
95 Mustang GT
I don't think he will need 30lbers with any reasonable heads he will put on the car. If he goes 347 then yes
#38 |
2001 Mustang GT
13.8@101.58mph!
i'd love to just get a supercharger but ill only have 2grand to work with.
#39 |
90 mustang GT
I have BBK colad air intake with filter,BBK pullies,electric fan,24 injectors with matching mass airflow, I would sell
Threads Similar to: Question thats been asked a thousand times
| This has prob been asked a 1000 times!! BUT? | MaverickGT | 94-95 | 37 | December 8th, 2010 01:13 PM |
| This has probably been asked a thousand times... | BlueScreaM | V6 Mustangs | 13 | August 23rd, 2010 07:27 PM |
| this has probably been asked a million times but | walt1120 | V6 Mustangs | 2 | April 22nd, 2010 10:26 PM |
| Been asked a million times.. | PeteGT | 99-04 | 8 | April 9th, 2010 09:34 AM |
| i know its been asked so many times. tire sizes? | buddyantunez1 | 99-04 | 10 | December 3rd, 2008 06:29 PM |
