2001 Mustang GT
13.8@101.58mph!
Question thats been asked a thousand times
Ok ive got a completly stock 90 LX.I getting ready to put every bolt-on under the sun on it.Pulleys,CAI,headers,h-pipe,and so on.Now the question is,with a stock intake and heads,What size TB should i go for 65mm or 70mm?.Also would there be any benefit by adding aftermarket 73mm C&L Mass Air Meter?
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
65mm would be fine for now, but do you have any plans of doing a h/c/i or fi down the road? if yes then might as well go for the bigger as it wont hurt anything now and help later.
the maf prolly will add a little bit but prolly not enough to justify the price of it. i would wait to upgrade maf's until you need to up your injector size.
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
2001 Mustang GT
13.8@101.58mph!
Im gonna have about 2grand to spend.I figured that wasnt enough for the h/c/i plus new TB,injectors and all the supporting mods,PLUS the install price.Thats why for now i was just gonna do all the bolt-ons first.What do you think?
what do you want the car for? do you want to go fast or slowly build it? that's the big question here. because if you want to make the car go fast, i say spend about 1k on buying some used parts such as longtubes, midpipe, mufflers, udp's, cai, etc. then buy some decent drag radials, and spend the rest on nitrous.
1989 Mustang GT 5.0
70mm will match most intakes perfectly, it matched my trickflow trackheat PERFECT
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#6 | |
1988 Mustang Gt
1988 Foxbody GT E-303 cam BBK Shorty Headers,BBK X-Pipe BBK Fenderwall Cold Air Intake Edelbrock Duel Timing Chain Pro 5.0 Short Shifter Mach 1 Fiberglass Hood Subframe Connectors NO Heater core, NO A/C ![]()
2001 Mustang GT
13.8@101.58mph!
I would like a quick street car.I also am installing 4.10'sWhat im thinking is get all the supporting mods for now,like the bolt ons and gears and drag radials.Then save some more for the h/c/i.That way ill have everything already.
#8 | ||
1991 Mustang LX 5.0
Forced Induction, super-turbo-nitrous Side note: Stock TB is 60mm and stock maf is 58mm. You can do the math I'm sure. Stock intake I would do a 65mm (I have one for sale if you are interested) and stay far away from the C&L in my opinion. I had bad results along with many, many other people, although Hatch is using one now. If you really want one that bad, I have the 76mm C&L with intake tube for sale too.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 Last edited by FastStang91Lx; November 3rd, 2010 at 09:06 PM. |
you may also want to put a little bit of money into suspension. you wont need it much with just bolt ons but once you start making decent power you will. by suspension i mean u/l control arms, struts/shocks, and maybe some springs. plus sub frame connectors.
2001 Mustang GT
13.8@101.58mph!
Yeah forgot to include full-length sub-frame connectors,and a strut tower brace.I have a convertible.Those are the FIRST things im doing.
1991 Mustang LX 5.0
Careful with strut tower brace. Not many work with aftermarket intakes.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
2001 Mustang GT
13.8@101.58mph!
Ah the question still remains.65mm or 70mm throttlebody?Should i just get 70mm for when i get the new intake?itll probably be cobra or gt40.They should clear the tower brace?huh
1991 Mustang LX 5.0
Should, just don't run a upper to lower spacer either. 70mm and port the stocker for now. I have 2 of them for sale too if you are interested. One BBK and one Accufab. The 65mm is a bbk
2001 Mustang GT
13.8@101.58mph!
Do i have to port the stocker for the 70mm to fit?
1991 Mustang LX 5.0
Yeah, but it's easy. Die grinder or cordless drill (cuz they spin faster than corded) but it would just take longer.
1991 Mustang LX 5.0
Side note to you or anyone else reading this - I have the matching egr spacers for all three TB's too.
2001 Mustang GT
13.8@101.58mph!
Cool
1991 Ford Mustang GT
buy the 70mm Accufab from Faststang91Lx. Accufab is a good brand
1991 Mustang LX 5.0
The BBK's w/ spacer are 100 shipped, and the accufab is 150 shipped.
i'd go 70mm. and you wont need to port your stock intake. it'll bolt right up to it and work fine, but the tb will just be larger than the intake so you wont get quite as much of a gain from it, but the porting isn't necessary.
Threads Similar to: Question thats been asked a thousand times
| This has prob been asked a 1000 times!! BUT? | MaverickGT | 94-95 | 37 | December 8th, 2010 01:13 PM |
| This has probably been asked a thousand times... | BlueScreaM | V6 Mustangs | 13 | August 23rd, 2010 07:27 PM |
| this has probably been asked a million times but | walt1120 | V6 Mustangs | 2 | April 22nd, 2010 10:26 PM |
| Been asked a million times.. | PeteGT | 99-04 | 8 | April 9th, 2010 09:34 AM |
| i know its been asked so many times. tire sizes? | buddyantunez1 | 99-04 | 10 | December 3rd, 2008 06:29 PM |
