1989 Mustang LX 5.0
slow..help
annoying clunking noise when i turn.
alright well im just starting to notice an annoying noise that i should probably get fixed before something worse happens... when i turn to go around a jug handle, or even turn at an intersection, in particular when i turn right, it makes a clunk, click like noise just one time... and when i backup, and turn the wheel all the way to the right, it just straight clunkclunkclunkclunk, and sounds like somethings going to fall apart... any ideas? thanks!
1988 Mustang GT
13.5@102
ball joint? jack it up and check it
99 Cobra - 92 LX - 90 LX
Yea, maybe ball joint. Jack it up and make sure there is no anything in there too.
Question: What does single life get you? Answer:
1995 Mustang GT
im gonna join everybody else with the ball joints...
fo sho the ball joint, i had this happen to me prior to replacing the whole front end. It will soon make a creeking noise turning the wheel left to right etc...
Dart Iron Eagle block & Pro 1 heads DSS 347 80lb injectors D1-SC blueovalindustries headers BBK o/r X Flowmaster cat-back 3.73 gears |
1989 Mustang LX 5.0
slow..help
yeah the creeking noise im starting to hear too.. sounds like its coming from my left tire, i thought it was low on air or something because it sounded like that creaking noise. thanks! and thanks everyone else!
This is your oppurtunity to buy something better.
1989 Mustang LX 5.0
slow..help
haha, but i like my lx. ive wanted one ever since i was a kid when i hopped in my uncles when i was 9. it felt amazing, 12 years later, i pick one up. i love it, but i'm afraid you may be right, im honestly thinking about either selling it and picking up a 11' 5.0, or riding it out and saving for a 11' cobra ...
Your missing my point! Not a better car, better parts for the car... ROFLMAO
Fox bodies are the best, I own 2. If you want an 11 5.0 buy it, but keep the Fox
1989 Mustang LX 5.0
slow..help
lmao i gotcha, dont worry i wasnt letting someone else decide on what im doing with the car haha..
it's either your ball joint or swaybar end link or bushing. If it's the ball joint replace it with a decent one like moog
101FNG IS MY MASTER! I LOVE HIM 4EVER!
85 GT, 87 LX
It could also be a cracked boot .... I have one right now and when i turn it makes like a low click click noise.. sometiems if all the oil drains out you have to get it reaxeled.
93 lx 5.0
i wasnt aware that the fox bodys were front wheel drive, lol. sounds like a ball joint (since no one else has mentioned that!)
85 GT, 87 LX
ah lol ........ see i drive a tercel ... which is def front wheel drive .. .and i have been so worried about mine i had it on my mind .. but if your fox just so happens to be front wheel drive then its prob your boot ......... if not then id go with ball joint ........
'93 GT HATCH catlesssssss
Fast?
would the problem also be the same if the noise isnt coming from when im turing but when im backing up and hit the brakes, as to shift the load to the back, i hear clunking noises from both sides up front......... only when braking backwards.....
1991 Ford Mustang GT
I have this same problem. it makes one or two clicks when you max out your stearing. i just replace my front sway bar bushings and sway bar end links and no change
Fast?
anything????????
1989 Mustang LX 5.0
slow..help
been a little busy, working 7 days havent had the time.. going to have it done this week, more towards friday, unless i decide on paying someone... let ya know then
could also be a bad strut mount but chances are a bad balljoint
Threads Similar to: annoying clunking noise when i turn.
| clunking noise when letting off throttle | mainejohn | 5.0 Mustangs | 24 | September 7th, 2011 11:53 PM |
| Clunking Noise from Rear | MyGG | 2005 - 2010 | 3 | September 2nd, 2010 03:26 PM |
| clunking noise | mxnate116 | 5.0 Mustangs | 16 | October 12th, 2008 02:35 PM |
| Clunking Noise? | XxViSiOnxX | V6 Mustangs | 3 | September 28th, 2008 05:11 PM |
| clunking noise wf???? some reading | 91cobra5.0 | 5.0 Mustangs | 7 | September 6th, 2008 03:31 PM |
