1966 Mustang with 1994 5.0 dipstick relocation
Old November 7th, 2010, 04:59 PM   #1
hhahaahyea's Avatar
1966 Mustang Coupe
hhahaahyea is on a distinguished road
Send a message via AIM to hhahaahyea
i wanted to do a T5 conversion for my coupe. i got a 5.0 HO and T5 from a 1994 GT. i got rid of the remaining fuel injection stuff on the engine when i got it and put a new intake and carburetor on it. we also swapped oil pans. it finally started last night.
(video with more detail for those interested in the process)
but now, the problem...i read about relocating the dipstick to the front timing chain cover but apparently that will not work in a 94-95 5.0.
the engine is obviously in the car now which makes it trickier...where should i relocate it?
any help would be appreciated.
Old November 7th, 2010, 06:00 PM   #2
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
if you were able to get your hands on an older carb timing cover, you could still use a front mounted dipstick. but you would need to find a way to block off the dipstick hole on the side of the block. This would be less of an issue if you had the engine out, i'd say take the oil pan off and use a small freeze plug to seal the hole... however.... this is not the case.
One option you do have is a LOKAR aftermarket dipstick tube, from the hole in the side of the block. It has a flexible tube and will allow you to run it away from the engine, to where ever you want it.
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old November 7th, 2010, 06:31 PM   #3
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
The older timing chain cover are now readily available from aftermarket companies.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 7th, 2010, 06:34 PM   #4
99 Cobra - 92 LX - 90 LX
pacopatron is on a distinguished road
+1 - that should help you
Question:
What does single life get you?
Answer:
  • 1999 Mustang Cobra
  • 1992 Mustang LX Vert
  • 1990 Mustang LX
Old November 7th, 2010, 06:54 PM   #5
hhahaahyea's Avatar
1966 Mustang Coupe
yeah i was hoping i could avoid buying something else though.
but the dipstick tube fits where it is, but since i had to change the oil pans it just scrapes into the high spot on the oil pan. when the engine is cold and it has the right amount of oil, there won't be any oil up there will there? i thought of just shortening the dipstick...the car is at an angle right now so i can't tell
also, i read about a guy who used a wooden dowel to plug the old hole
Old November 15th, 2010, 06:43 PM   #6
hhahaahyea's Avatar
1966 Mustang Coupe
someone on another forum suggested drilling through the pan. if i was able to weld something in the hole i drill, could i do something like that?
Threads Similar to: 1966 Mustang with 1994 5.0 dipstick relocation
1966 with carbureted 1994 5.0 starter/solenoid wiring help hhahaahyea 5.0 Mustangs 12 October 9th, 2010 05:05 AM
1966 Mustang GT 66mustang619 Classic Mustangs 29 June 10th, 2010 12:18 AM
1966 Mustang MARKb47 General Tech 0 March 5th, 2010 04:42 PM
1966 Mustang Gearbox rjlope66gt Classic Mustangs 4 February 22nd, 2010 07:28 PM
1966 mustang truck? Vinyl66 The Clubhouse 5 August 7th, 2008 06:20 PM
