Need help removing starter motor
Old November 8th, 2010, 05:18 AM   #1
PsyAbe's Avatar
'92 LX
PsyAbe is on a distinguished road
Send a message via AIM to PsyAbe
Unhappy
No article I've read seems to be comprehensive enough, so as a last resort this is my shot at getting my questions addressed directly. I have a 5.0 with long tube headers. From above the engine, all I see is what I think is the mounting arm of the starter motor, extending out of the transmission's bell housing. From under the car I can't pinpoint a thing. Bare with me as this is my very first take at doing anything related with mechanics, but I'm good with tools and I'm determined.
1) Since my headers are long tube, I suppose they HAVE to be removed? They do seem to get in the way of everything
2) Is removing the headers a straight-forward unbolting procedure for this specific task? Or do I have to worry about things I've read in header removal threads like the EGR and whatnot? Those guys wanted to replace headers, not only get them out of the way
3) After unbolting can I just set them aside or do i have to remove them entirely from the engine bay?
4) Would a torque wrench be absolutely necessary? Or can I just count how many rotations it took to loosen the starter motor bolts?
5) Can any of this be done from above? Or is it a necessity to crawl under?
Thanks in advance and sorry if any of this was answered before, I'm just a little nervous seeing that this is my very first take.
Old November 8th, 2010, 05:40 AM   #2
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
I have never done this job on a ford with long tubes. With shorties, it is a straight forward and easy procedure. Unbolting your headers and moving them out of the way doesn't sound like a bad idea in order to gain some more room to work. (remove your spark plugs first so you don't decapitate one with the header.) I wouldn't bother with taking the header all the way out, I would just loosen it and tie it out of the way.
I don't think that there is a bracket supporting the starter. They are usually bolted to the bell housing with 2 bolts. one on top and one on the bottom. You may be seeing the starter cable and think it is a bracket.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Last edited by jessemachone; November 8th, 2010 at 07:57 AM. Reason: grammar police
Old November 8th, 2010, 08:32 AM   #3
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
You need a long extension to reach the top bolt. If you dont have that your gonna be shit outta luck. The bottom can be done with a 3" extension and you should be good. I had long tubes on my race motor and thats what i had to do.
Old November 8th, 2010, 09:26 AM   #4
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
You have to remove the starter from under the car. I've removed mine twice (I have shorty headers) and I tighten it without a torque wrench. No problems yet. The starter is just 2 bolts and there is one bolt for the wire.
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old November 8th, 2010, 09:34 AM   #5
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
I used 12", 6", and a 3" extension and a swivel (all together) to get to the top bolt and went through my A-arm. the bottom one is easy and out in the open. The top one can be a little bit of a bitch, but just take your time and don't get frustrated...easier said than done!
You should be able to get to it without removing your headers.
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Old November 8th, 2010, 09:35 AM   #6
1992 Lx
11.39@119.24
top bolt from above the motor, easy as shit to get to, bottom bolt I can get off without even jacking my car up. Lay on the floor next to the car and reach up there with a small rachet, easy to get to. And yes my car has long tubes
Old November 8th, 2010, 03:54 PM   #7
mutlyi4's Avatar
95 mustang gt
mutlyi4 is on a distinguished road
i have an 84 gt with headman longtubes and i have to unbolt the motor mount jack the motor up a little and then pull the header off then starter removal is simple and i have never used a torque wrench for a starter just put them in tight but dont stripe the threads in the bellhousing
Old November 8th, 2010, 07:22 PM   #8
The Big Spoon
never fast enough
lol! you must not be riding all that low! my shit is too low for any of that business. I have just about an inch between the fender and the tires. It isn't slammed - just low.
you're my hero
thread jack complete
Black Stang Crew
Old November 8th, 2010, 08:00 PM   #9
1992 Lx
11.39@119.24
My cars a lil lower than stock, I've just done it so much I can do it blindfolded. Easy to feel along the bellhousing for the bolts
Old November 8th, 2010, 08:10 PM   #10
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Have you tried removing the front passenger side tire and fenderwell cover? I did this with my 87 and It helped alot with access.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old November 8th, 2010, 09:10 PM   #11
The Big Spoon
never fast enough
it is just too easy for me to drive it up the ramps..... I guess I could use the Ray Charles metnod if I had to.
Black Stang Crew
Old November 8th, 2010, 09:24 PM   #12
1992 Lx
11.39@119.24
Lolzzzz just sayin once you know where the bellhousing is its easy as shit to feel around for the bolts
Old November 10th, 2010, 04:22 AM   #13
PsyAbe's Avatar
'92 LX
Ok first of all thank you all for your helpful advice. Here's an update: I was able to locate the starter after all, turns out I hadn't crawled in deep enough to see it the first time I was down there. I proceeded to loosen the lower bolt, no problems there. However, due to me focusing hard on solely locating the damn thing, I completely forgot to unhook the negative cable from the battery. When I located the upper bolt and FINALLY managed to find a way to reach it with my wrench..well..sparks started flying like the fucking 4th of July (Turns out I hit the main voltage terminal). I freaked the fuck out and got the hell out from under there. I was too disoriented at first to realize it was my carelessness that caused that, I thought the starter cable short circuited or something and was about to ignite.. Anyway, I'm going back in, but one thing I noticed when I was down there was really starting to concern me: One way or the other, I think I can pretty much loosen the starter and pull it out. However, from where I was sitting, it seemed next to impossible to later install the replacement starter, as in, to be able to hold it up with one hand and insert the upper bolt and cable with the other. Any comment on that?
Old November 10th, 2010, 07:58 AM   #14
Digsj7's Avatar
1993 Mustang LX
You just have to go in at an angle and wiggle it in there. I always put the bottom bolt in first, thread it in most of the way so the starter doesnt sag and put the top bolt in. Done! Depending how long your starter cable is, you will probably have to hold the starter up with one hand and put the cable on with the other. Do the power cable first, then bolt up the starter.
Old November 10th, 2010, 09:15 AM   #15
95tbirdv8's Avatar
1990 mustang gt
Done it by myself a couple of times, it can be done. If your not confident get someone to help you hold it.
Old November 10th, 2010, 09:25 AM   #16
91 Mustang GT
1991 sliver GT
DISCONET THE BATTERY. The starter gets its main power from the battery terminal. But lick your fingers and try it again first.. "just kidding dont do it"
Old November 10th, 2010, 06:28 PM   #17
FastStang91Lx's Avatar
1991 Mustang LX 5.0
..... Anyway, I'm going back in....
Way to be a trooper, lol
You won't feel 12v through your fingers even when wet, or at least I never have, but who doesn't check 9v batterys by putting them on your tongue?
Old November 10th, 2010, 06:45 PM   #18
WHT306's Avatar
1992 MUSTANG GT
N/A
WHT306 is on a distinguished road
[quoteI used 12", 6", and a 3" extension and a swivel (all together) to get to the top bolt and went through my A-arm. the bottom one is easy and out in the open. The top one can be a little bit of a bitch, but just take your time and don't get frustrated...easier said than done! ][/quote]
What he said
Old December 9th, 2010, 04:37 AM   #19
PsyAbe's Avatar
'92 LX
OK, so I did it. The bottom bolt as mentioned by many was a breeze to get to. The top bolt, however, was a hellish ordeal. With assistance from a neighbor I removed the headers (which I absolutely HAD to do since they were obscuring the entire lower half of the engine bay and from bottom the top bolt was inaccessible), and that was no walk in the park as it turned out. The thing is though, after I removed the starter, I hooked it up to the car's battery from an external cable and that thing torqued like its life depended on it. So sadly, it wasn't the starter motor that was the problem :/ Here's another thread of mine that I've started before creating this one, trying to determine the cause of the startup problems I've been experiencing. And a personal thank you for all your help.
Starter Motor Failling Regardless the Temperature
Threads Similar to: Need help removing starter motor
Starter Motor Failling Regardless the Temperature PsyAbe 5.0 Mustangs 14 December 9th, 2010 05:07 AM
97 Cobra, Starter Jolts, but motor does not Turn Kimo General Tech 3 May 14th, 2010 10:14 PM
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
