92 Lx
Slow
mounting points?
im pullin my motor out of my 92 lx... where are some good mounting points to lift it out by.... do i just use the bolt holes where the upper intake bolts to the lower intake?
1992 Lx
11.39@119.24
if you have any old head bolts laying around use them, front of driver side head and rear of pass side head, or vice versa. Head bolts screw in perfectly where the holes are for accesory brackets, done it this way past 3 times
1991 Mustang LX 5.0
I've used the holes in the lower intake many times, but I do wonder if that is such a good idea.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
92 Lx
Slow
i really didnt want to pull the heads off to do this... im mainly pullin the motor cause im pullin the trans to replace the clutch. so i figured i would paint it and clean up the compartment... any other sugestions
With what 93hatch said you don't need to pull the heads.
Dart Iron Eagle block & Pro 1 heads DSS 347 80lb injectors D1-SC blueovalindustries headers BBK o/r X Flowmaster cat-back 3.73 gears |
92 Lx
Slow
95pony....not tryin to be stupid but please explain... just remove the valve covers and then where do i bolt the chains?
95gt,67maro,05sti....
14.8@93,13.6@101,
don't remove valve covers. remove accessories, power steering, ac, etc.. use the bolt hole that held these on and corresponding hole in head at opposite corner.
1992 Lx
11.39@119.24
no no no not physically use the existing head bolts, I used head bolts as an option cuz theyre the same thread size as the front accesorys
Threads Similar to: mounting points?
| Mounting tuner | OHHitsKB | 2005 - 2010 V6 | 3 | August 19th, 2010 02:55 PM |
| Spoiler Mounting | 04stang123456789 | V6 Mustangs | 7 | April 13th, 2009 05:22 PM |
| need help to ID a mounting plate | crappy_head | 99-04 | 2 | February 14th, 2009 04:16 PM |
| HID Mounting help? | PowerShiftz02GT | 99-04 | 21 | January 8th, 2009 09:12 PM |
| mounting gauges | 03TropicGt | 99-04 | 7 | September 8th, 2008 12:04 PM |
