85 trans question
Old November 10th, 2010, 07:36 PM   #1
mutlyi4's Avatar
95 mustang gt
mutlyi4 is on a distinguished road
85 trans question
i am working on my friends 85 lx 2.3l and the 5spd trans is jammed in neutral does anyone have any info to help solve this problem or better yet a diagram of how the trans is put together any help would be great thanks
Old November 10th, 2010, 07:41 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
You usually have to press in the clutch to put it into gear. Have you tried that yet
Other than the smartass comment... I got nothing
Old November 10th, 2010, 07:43 PM   #3
mutlyi4's Avatar
95 mustang gt
yes the shifter inside is jammed in neutral between third and fourth gear
Old November 11th, 2010, 05:41 PM   #4
mutlyi4's Avatar
95 mustang gt
nobody has any ideas ???
Old November 11th, 2010, 06:15 PM   #5
WhiteMamba's Avatar
88 Notch
WhiteMamba is on a distinguished road
it sounds like a clutch problem...maybe the throw out bearing. Try pumping the clutch with the car running and pulling it into neutral.
88 Notchy
306 with 70mm Turbo
510 RWHP on 10lbs
K thnx
Can we chat?
Old November 11th, 2010, 06:47 PM   #6
mutlyi4's Avatar
95 mustang gt
i have the trans out of the car now and its an internal problem its jammed in neutral and over to the side like in between third and fourth gear so i guess something broke in the gearbox
Old November 12th, 2010, 03:25 PM   #7
mutlyi4's Avatar
95 mustang gt
turned out to be a worn out tail shaft housing
Threads Similar to: 85 trans question
trans question jkeyz 5.0 Mustangs 3 August 19th, 2010 12:39 AM
trans question osa6637 2005 - 2010 1 October 23rd, 2009 12:29 AM
Trans question. VOLIPINO Modular Mustangs 3 April 18th, 2008 08:43 AM
Trans question. VOLIPINO 5.0 Mustangs 12 April 17th, 2008 09:55 AM
86 5.0 trans Question? 86foxgt 5.0 Mustangs 1 April 11th, 2007 10:07 PM
