rear main leak
Old April 10th, 2007, 01:10 PM   #1
94 Mustang GT
kreil45 is on a distinguished road
rear main leak
just had rear main seal replaced and it still leaks from there. the gasket on the oil pan looks good and they said it was good when the had the tranny down. they also said there was no scaring were the seals goes. its an 89 GT 5 speed. any ideas?
Old April 10th, 2007, 01:23 PM   #2
B.A.M302 is on a distinguished road
Send a message via AIM to B.A.M302
The seal wasn't done properly.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55,
Old April 12th, 2007, 02:22 AM   #3
92fox is on a distinguished road
its a ford, 9.5 out of 10 fords rear main will leak, normally its not to bad but if its pretty bad go back to the place and tell them
Old April 12th, 2007, 07:46 PM   #4
86blkmustang's Avatar
86blkmustang is on a distinguished road
Send a message via AIM to 86blkmustang Send a message via Yahoo to 86blkmustang
the seal probably isn't seated right
Old April 13th, 2007, 01:44 AM   #5
There's supposed to be some sort of silicone put on each side of that seal to prevent it from leaking ask them if they did that.
Old April 13th, 2007, 10:16 AM   #6
nymustang50 is on a distinguished road
Send a message via AIM to nymustang50
Usually if its leaking and you replace it it will still leak or get worse. Thats just how fords are.
Threads Similar to: rear main leak
Replacing Rear Main Seal 5pointZero 5.0 Mustangs 5 June 17th, 2007 08:36 PM
rear main seal? marks87gt 5.0 Mustangs 4 April 26th, 2007 05:16 PM
Rear main seal leainking demononwheels 5.0 Mustangs 54 February 24th, 2007 07:39 PM
Rear main leak troy1000rr 94-95 1 December 31st, 2006 11:43 AM
Rear Main seal 1gunner23 5.0 Mustangs 5 May 11th, 2006 11:53 PM
