Engine Help 331 Stroker Build
Old November 11th, 2010, 09:49 AM   #1
CompOrangeSN95 is on a distinguished road
I have a 302 that I got for free and I have big plans for it, but I'm a little cloudy on some things, I'm going with a probe industries PRO STREET 331 stroker kit, dart pro 1 comp heads 62cc combustion chamber 195cc intake runner, 1.6 roller rockers, I'll be running a dual plain intake and 750cfm carb but I have no idea what cam to put in it... it's being built for a road race application and will constantly be turning high rpm 4K-7K, any idea what cam I should be looking at? Does anyone know if I'll see any power gain by switching to 1.7 rocker arms instead of 1.6? Any problems with this set-up? I'm looking to make 400+rwhp N/A. I welcome any advice, thanks in advance guys.
Old November 11th, 2010, 10:55 AM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Just from the few things you said here, I would suggest doing some homework. I always thought Pro Street was a dragracing class??????
First off, why would you limit yourself on cubic inches with a 331? You can do a 347 for the same money.
Secondly, where do you plan on finding a dual plane intake that will support 7000 RPMs? If you're planning on making any power that high, you will have to use a single plane.
On a build like you're talking about, a custom cam is going to give you the best results out of all your parts. They don't cost all that much more than an OTS cam, and are worth it IMO.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 11th, 2010, 11:21 AM   #3
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
why 331 when you can go to a 347 for the same price with no ill effects, and why a dual plane when you plan on generally running high rpm just use a single plane
Old November 11th, 2010, 11:22 AM   #4
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Is there an ECHO in here?
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 11th, 2010, 11:24 AM   #5
the reason I'm sticking with a 331 instead of a 347 is because of where the wrist pin is located on a 347, because of the large stroke it is moved up so far in the piston that it interferes with the lower piston ring leading to increased oil usage and shorter life span, the 331 on the other hand doesn't interfere with the piston rings, as far as the intake, I will take your advise on that and look into the single plane manifolds, and yeah pro street is for drag racing but when it comes to a rotating assembly it's all about the materials, this kit is all forged and that's what I want in case I ever decide to get a power adder, I wont have to worry about my bottom end being able to handle the stress. Thanks for the advise on the cam as well, I think COMP cams will do custom grinds
Old November 11th, 2010, 11:26 AM   #6
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Wait, couldn't you have gone with a 427 instead of a 408 for the same price too?
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old November 11th, 2010, 11:27 AM   #7
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
When will this myth die? The info on the 347 is completely false. There are no such dangers with the 347.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 11th, 2010, 11:28 AM   #8
1992 Mustang LX
13.0 @ 105
Here we go....Talk to 1slo5.0 on here. He's had multiple 347's and he says they never gave him one lick of trouble.
Old November 11th, 2010, 11:29 AM   #9
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Yes, if I wanted to buy new heads. I can make just as much power with the 408, as the 427 because my 185s are going to limit me if I go with a bigger CID.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 11th, 2010, 11:31 AM   #10
1992 Mustang LX
13.0 @ 105
Gotchya
Old November 11th, 2010, 11:42 AM   #11
If it really is a myth, then I agree with you guys that a 347 would be a better choice, I'll have to do some digging.
Old November 11th, 2010, 12:09 PM   #12
Smirnoff's Avatar
1982 GT t-top
guess i should read the replies before i post haha
Old November 11th, 2010, 12:18 PM   #13
what kind of power difference would I see going to a 347 instead of a 331 based on what I said I'll be running, single plane instead of dual
Old November 11th, 2010, 12:18 PM   #14
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Most Probe storker kits use the exact same piston weather its a 331 or 347. They just use a 5.4 rod in a 331 and a 5.315 in a 347. I've built several Coast/Probe 347's and none of them had the pin in the oil ring! And none of them have had any duribuility problems!
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old November 11th, 2010, 12:23 PM   #15
Awesome, I did some searching on other forums and people say the same thing, looks like I'll be doing a 347 instead of a 331, anyone have an idea of what kind of power I can expect to make using those heads? Vic Jr single plane intake holley 750cfm 4 barrel
Old November 11th, 2010, 02:08 PM   #16
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'm not too sure what those heads flow, but I would think you should be able to surpass that 400hp mark you mentioned, with a good custom cam.
Good choice of intake
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 11th, 2010, 02:15 PM   #17
I found some flow numbers on the Dart Pro 1 CNC. It looks like they flow 299 intake @ .650 and 220 @ .650.
01 Ram Quad Cab
03 Grizzley 660
Old November 11th, 2010, 02:26 PM   #18
1992 Lx
11.39@119.24
My 347 burns a quart a day if I drive it regular or 9 quarts a day if I drive it backwards
Old November 11th, 2010, 02:34 PM   #19
Awesome, thanks for the help! A couple months and I will start ordering parts, I love when boxes show up at my house lol
93hatch, what your trying to say is I should bring oil with me every time I go racing? haha
Threads Similar to: Engine Help 331 Stroker Build
331 stroker or 306 stroker? S/C or N/A 91Mustang GT 5.0 Mustangs 6 December 8th, 2010 11:00 AM
331 Stroker 68 dlxcoupe 5.0 Mustangs 17 June 16th, 2009 11:09 PM
How to build a 331 stroker Drick 5.0 Mustangs 10 January 25th, 2008 08:57 PM
Anyone Done A 331 Stroker White 89 5.0 Mustangs 65 October 4th, 2007 04:59 PM
331 Stroker purplepony96 5.0 Mustangs 2 November 13th, 2006 09:29 PM
