Gauge cluster question
Old November 11th, 2010, 08:32 PM   #1
orangestang42's Avatar
1995 Mustang GT
orangestang42 is on a distinguished road
ok i have a 1995 mustng v6 body with a v8 motor in it, the question i have is, i have the v6 120 mph cluster still and i wanna swap it out to the v8 one, is it a direct swap? or is there re-wiring needed?
thanks
Ryan
Old November 11th, 2010, 09:19 PM   #2
1998 Mustang GT
I don't know@I like turns.
jdub is on a distinguished road
Should be a rewiring because the gauge is gonna read off by a lot if the engines are moving faster. but then again it could just need the speed calibrator fixed by a shop.
Old November 11th, 2010, 09:35 PM   #3
Proud American
MustangMatt96GT's Avatar
Im pretty sure its just a direct swap... the VSS is a signal that is calculated off the transmission and so it sends an electrical signal to the cluster... I would try it...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old November 11th, 2010, 09:46 PM   #4
AdderMk2 will become famous soon enough
Send a message via AIM to AdderMk2
should be a direct swap. The wiring didnt change for the clusters until the 4.6l engine IIRC
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL]
[SIGPIC][/SIGPIC]
[QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE]
Old November 12th, 2010, 12:54 AM   #5
1995 Mustang GT
ok cool, i figured it would be because these clusters have mechanical speedo gauges which means it reads how fast the car is going regardless of the engine, thats what led me to believe it would work, i just wasnt sure about the wiring
Threads Similar to: Gauge cluster question
Gauge Cluster ? silver99gt 99-04 6 September 11th, 2009 01:50 PM
99-04 gauge cluster? ZoomZoomMFer 99-04 23 August 6th, 2009 11:14 AM
Gauge Cluster Euroeater95 94-95 2 May 20th, 2007 08:55 AM
swapping '95 V6 gauge cluster to a '94-'98 GT cluster? Alocatelli V6 Mustangs 3 April 4th, 2007 02:38 PM
