302 rebuild, need opionions.
Old November 12th, 2010, 05:08 PM   #1
herman0203 is on a distinguished road
Currently rebuilding a 302 that came out of a bronco. I'm putting the motor in an old CJ Jeep so I did away with the EFI. Obviously the intake and carb will be needed, but what else will be needed? Distributor and fuel pump?
I believe the stock horsepower was about 180? I'm looking to get at least 250 with the intake carb cam headers and heads. What is my best option as far as the heads? Bolt on some used gt40 heads or get some work done to the stock heads?
Old November 12th, 2010, 05:14 PM   #2
95StangMX's Avatar
95 Mustang GT
dont waste your time with the stock ones, pick up a set of exploder heads if you are just doing a budget build it should get you pretty close to your goal.
Old November 12th, 2010, 05:37 PM   #3
I also heard that the edelbrock performer intake will not work with the gt40p heads. Is this true?
Old November 13th, 2010, 01:17 AM   #4
centipede3001 is on a distinguished road
gt40p heads are a pain because of the spark plug angle just go with the regular gt40 heads and save yourself the hassle
Old November 13th, 2010, 10:38 AM   #5
1992 Lx
11.39@119.24
better make sure its a roller block, alot of the truck blocks arent. My 91 F150 isnt
Old November 13th, 2010, 11:37 AM   #6
86 Mustang GT
steve86gt is on a distinguished road
A little more info on the 302 would be helpful. A roller block is definitely preferred, because then the gt40p heads and valvetrain would essentially bolt up. p heads also do not have exhaust gas ports on the back like many stock efi motors for the air pump system. If you have a non-roller block, you should be able to use the p heads but you may have to get custom length pushrods depending on the rocker arm setup. With a mild cam (under .500 lift int/exh), a decent dual plane intake, a 600cfm carb, small-tube headers, and proper timing you should meet or exceed 250hp. The spark plug issues with p heads generally comes from header fitment. Look for stock 5.0 mustang headers if you cant reach the plugs. I'm not sure about adapting the efi distributor.
Good luck
Old November 13th, 2010, 11:57 AM   #7
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
no they're not at all actually
Old November 14th, 2010, 02:36 AM   #8
well the regular gt40 heads are a lot easier
Old November 14th, 2010, 02:10 PM   #9
First off, how do i tell if i have a roller block? And are there any performance differences between the gt40 and gt40p heads?
Old November 14th, 2010, 02:26 PM   #10
86 Mustang GT
If you have a roller block, you will see a "spider retainer" and dog bone shaped guides between adjoining lifters. If the block is disassembled, you will see two threaded bosses in the lifter valley that the spider retainer bolts to. Gt40 heads are definitely easier as the spark plug angle is compatible w/ all other sbf heads, but they tend to be harder to find. I'm sure gt40x heads have bigger valves than p heads, but p heads have small combustion chambers. (58cc) This will bump the compression a bit. Try for gt40s, but go with gt40p if you can't find a reasonably cheap set.
Old November 14th, 2010, 02:29 PM   #11
No i dont have a roller block then. Will the gt40 heads still bolt up and edelbrock intake? What is my best option here.
Old November 14th, 2010, 05:15 PM   #12
it should youll have to look at pictures of them online and see it it looks like your intake but it should
Old November 16th, 2010, 12:11 PM   #13
Can anyone confirm that the edelbrock rpm intake or performer intake bolts onto the gt40p heads?
Old November 16th, 2010, 12:23 PM   #14
1992 Lx
11.39@119.24
bolts on yes ports lining up perfectly, no. But 98% of people with 5.0s who put aftermarket intakes dont check anyways
Old November 16th, 2010, 01:44 PM   #15
95StangMX's Avatar
95 Mustang GT
Don't listen to this, the p heads will work fine, just have to use different spark plug wires, big deal.
Old November 16th, 2010, 04:50 PM   #16
What is a good mild cam to go along with the gt40p heads?
Old November 16th, 2010, 05:47 PM   #17
Smirnoff's Avatar
1982 GT t-top
tfs1 or AFMn41 seem to work well for ots cams
Old November 16th, 2010, 06:02 PM   #18
1992 Lx
11.39@119.24
Put a stock speed density cam in the truck if its automatic
Old November 16th, 2010, 07:00 PM   #19
the motor will be going in a jeep with a 3 speed btw
Old November 16th, 2010, 07:04 PM   #20
1992 Lx
11.39@119.24
Call comp and ask them. Nobody here is exactly pros at building 3 speed truck engines
Threads Similar to: 302 rebuild, need opionions.
302 rebuild price sickfox 5.0 Mustangs 4 August 5th, 2010 08:22 AM
best 302 rebuild Stangin94GT 5.0 Mustangs 9 July 24th, 2010 03:31 PM
302 rebuild cam302 5.0 Mustangs 9 April 21st, 2010 07:09 PM
302 Rebuild Nitrous Injected 5.0 Mustangs 10 October 22nd, 2008 01:35 PM
302 rebuild doe302 5.0 Mustangs 0 June 25th, 2008 12:42 PM
