Discussing 8.8 posi in the 5.0 Mustangs Forum. i have a 8.8 rear with 3.08 i want to add a posi ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
8.8 posii want to add a posi unit and 3.73 or 4.10 what the cheapest best way to do this or should i go with a whole new rear from say junk yard
scotty ![]() 1990 GT 5.0 1.550 60ft 1/8 slow 1/4 slower |
just buy the new ring and pinion set. Better look into a new rebuild kit with shims and bearings etc. Altogether it will run you about $250 or so.
There are alot of places to buy them. Check out www.brenspeed.com
Suck on it Trebek. Suck it long, suck it hard.
2001 svt cobra
10's I wish
I thought the 8.8 was posi?,or limited-slip? anyway whats the difference
created 5/29/2001 on Tuesday, #1249 of 3867 ![]() 1 of 556 in silver metallic |
you might have a limited slip. what is your axel code? if it is a "z" you have a 3.08 w/ ltd slip. if it is a "y" you dont have a ltd slip.
its cheeper to rebuild the ltd slip than to buy a new one. |
2001 svt cobra
10's I wish
whats the difference limited or posi?
well doing a burnout only the pasenger side tire spins
It is not a limited slip its a single track rear with 3.08 out of a 92 mustang my gues a 4 banger i was under the impression that ford put limited slip in all there 5.0 stangs or am i wrong so it is cheaper to build this rear and ad the limited slip and gears or try to find something drum to drum allready setup
2001 svt cobra
10's I wish
so, limited-slip both tires will spin at the same time. I got mine with 3.73 gears for about $250 at a junk yard
well the trac loc could need a rebuild too
yeah that what i think is wrong the clutches are gone in this rear
thanks
1990 Mustang GT
9.39@76.09----1/8th mile
+1 on the trac lok needing a rebuild......they have kits to rebuild them at the ford racing website. 50 buck for a regular kit or about 110 for a carbon disc kit
![]() stang=40's dumped,pro 5.0 short throw, king cobra clutch, adj. clutch cable and firewall adjuster...pretty much stock 2001 tacoma=magnaflow, K&N cai, tb spacer, 2.5" susp. lift, 32x11.50s, electric fan, few dress up items |
you could use f150 clutches in rear they are stonger also i think you can add an extra one to make the limited slip a little stonger where both tires will spin
Threads Similar to: 8.8 posi
| Trac Lok Posi vs Eaton Posi? | cosworthpower | Modular Mustangs | 4 | April 24th, 2008 03:01 AM |
| WTB: 3.55 posi-'87 8.8 | marks87gt | Want to Buy | 0 | October 6th, 2007 07:50 PM |
| Posi!!! | StangFreak4 | Suspension | 2 | August 1st, 2007 10:01 AM |
| Posi!? | AJRight 2008 | V6 Mustangs | 4 | November 8th, 2006 09:49 PM |
| how much is posi? | 96GT_Driver | 96-98 | 2 | August 15th, 2006 06:51 PM |
