deal or no deal
is his a good deal, and is traction lock and limited slip two different things?
95 opalfrost gt
Its basically stock rear with gears and 5lug. I think you would be able to do gears and 5lug cheaper than that.
and the discs. i have a fox body. they never came with discs.
Trac lock and limmited slip are close to the same. trac lock has beter clutches and a presure retainer spring and limmited does not.I recomend trac lock for a musyng ford racing's is damn good.A full lock is for racing and is no good for street.The cheapest way to get 5 lug rear disc is to uses 94 up rear axles calipers with brackets and hoses. The axles are 1.5 in longer because of rotor not drum and will move the wheels out but looks good use your master cyl.that is a good deal if your wanting those brakes then you would have to get the fronts.you could go alot cheaper.
Threads Similar to: deal or no deal
| good deal or bad deal!!!!!!!!91 coupe and 5.0 engine | kngkahious | 5.0 Mustangs | 11 | June 6th, 2007 01:38 PM |
| Is This A Deal Or What? | WAVEBYE | 99-04 | 17 | January 13th, 2007 05:07 PM |
| what a deal.... | Kingcater | Audio/Video | 4 | January 10th, 2007 07:48 PM |
| Good deal or No deal??? | Hoss | Classic Mustangs | 17 | January 9th, 2007 09:23 PM |
| 2006 Mustang - Deal or No Deal? | PacMan66 | 2005 - 2010 | 8 | November 30th, 2006 09:58 PM |
