Sunroof leaking
Old November 14th, 2010, 01:15 PM   #1
97gtstang is on a distinguished road
Sunroof leaking
The factory sunroof on the my 93 leaks. I recently replaced the retaining bolts/washers that hold it through the glass, and the glass to body weatherstirping. I still have a small leak coming from the clip holders seen here
Im no expert, but i was thinking I could use that gasket stuff that comes in the tube to seal them up but I didnt want to mess them up if that wouldn't work.
someone must have info on how to fix this problem/had the same problem
07 Roush Fastback Package
93 2.3 LX project car!
They all think it has a 5.0 ... n00bs
Old November 15th, 2010, 10:26 PM   #2
bumpity cause its raining like hell here. only a few drops leaking in, but I want to put a new headliner in and not get it ruined... I know someone has had this problem or knows what to do
Old November 15th, 2010, 10:33 PM   #3
95tbirdv8's Avatar
1990 mustang gt
95tbirdv8 is on a distinguished road
Sorry for the helpless post but there isn't a lot of foxbodys with sunroofs
Burning Rubber in the 5.0
http://www.youtube.com/watch?v=mKGSmRkKQcM95
95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6
to be continued........
foxbodyperformance.com is the way to go
Old November 16th, 2010, 09:14 AM   #4
nolife's Avatar
91GT, 88GT, 02GT
EDIT. I just reread your post.
Yes, you can seal them up. I personally would remove them, clean off the old gasket material and reseal them completely with some clear RTV (don't overtighten them, mine were brittle) Also while your headliner is off, verify your four drain hoses are on tight, not cracked, and cleared from debris and can drain freely. With those yellow things sealed and the hoses draining properly, the roof will never leak into the car regardless of the condition of the sunroof gaskets.
PS...
About your headliner. If you are going to be searching for one, let me know if you find a replacement that has the vinyl material like the original cars with a sunroof had. I gave up looking and eventually bought an ABS headliner with cloth material already attached. It works and looks fine but I really want the original style material.
Old November 16th, 2010, 09:44 PM   #5
ryanw's Avatar
1991 Ford Mustang GT
PS...
Are you looking for a vinyl head liner ? Those are nice ive only seen it on one mustang it was on a 1986 t-tops. Do they make them for 91 stang gt with out the sunroof ? i think that would look great in my car over the cloth
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 16th, 2010, 09:58 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
Originally Posted by ryanw View Post
Are you looking for a vinyl head liner ? Those are nice ive only seen it on one mustang it was on a 1986 t-tops. Do they make them for 91 stang gt with out the sunfoof ? i think that would look great in my car over the cloth
The later foxes (at least 91-93) with a factory sunroof had a very specific vinyl headliner that was different from the ones without the sunroof. It was a thin vinyl with a slight dull rough texture. Some of the four eyes had a smoother vinyl and I've seen them in the aftermarket but they are perforated vinyl and/or not available in the 91-93 titanium color. I've found headliner material in a local craft store that is close enough but I didn't want to take off the cloth material from the ABS plastic replacement headliner I just bought to try it and my original cardboard headliner frame is too weak to reuse. If someone had the correct titanium color vinyl headliner with a ABS plastic backer board, that would be ideal, I gave up looking and I got tired of driving around with no head liner waiting
If you don't want the specific titanium color and don't mind a "different" vinyl from stock, I'm sure I've seen vinyl replacements for the later foxes in my searches.
Old November 17th, 2010, 04:09 PM   #7
Thank you thank you!!! +1 to the reps.
Ill pull them all the way off tomorrow and try to seal them up. I had already checked the drip channels and after replaceing all the through glass hardware ran up to the carwash to see where else it was leaking.
as for the headliner the one I took out was a bad replacment with cloth. I was looking at getting just the ABS one like you had (missed a brand new one on ebay by one dollar $76!!). I did see someone who made custom ones on ebay, but Im not sure if they were the vinyl ones or not, I'll have to check.
Thanks again!!!
Threads Similar to: Sunroof leaking
sunroof??! papemilio V6 Mustangs 15 June 12th, 2010 03:57 PM
Sunroof on 99 cobra? KDewCobra 99-04 5 May 23rd, 2010 01:07 AM
Sunroof Zatrekaz Visual 16 December 22nd, 2007 11:38 AM
sunroof spero 99-04 4 April 9th, 2007 12:09 PM
sunroof on mustang gt droppedbass87 Visual 6 March 11th, 2007 01:53 PM
