1989 LX
12.60 at 109mph
Boost losers, quick question
Car has a novi 1000, 6 psi blah blah, am I suuposed to delete the pcv valve in the back of the intake? Im pretty sure its whats blowing oil all over the place and its not the lower intake rear gasket. Should I just cap it, and glue the bitch in with rtv? PS 93hatch has a very big weiner
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears soon to come 30lb injectors, Blow through MAF, intercooler and tune |
#2 | |
1991 Mustang LX 5.0
And about Hatch's johnson..... Trust me... I know... Still can't sit down right.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1989 LX
12.60 at 109mph
Figured it was whats blowing oil all over the place. Valve cover is vented so the crank case shouldnt be pressurized if I delete the rear one. Fuck it now that sexy sexy man wont have to work his sexy body any harder pulling the lower. PS 93hatch has a giant penis
1991 Mustang LX 5.0
Get off your roommate - and his account. lol. I think it was nolife that was talking about that once, and that you would basically have a tiny vac leak the way it is now, but if you were tuned like that, or some shit, then you just leave it. Something like that anyway.
1989 LX
12.60 at 109mph
na pos isnt tuned just fmu with the stock 19s. Only worry is if the stock valve cover being vented is enough if I just plug the rear pcv
1993 5.ohhhh
12.97 @140mph
My strim at 10psi and turbo at 10psi with one breather over the oil filler with the stock pcv wouldn't spit out any oil. Car wouldn't burn oil through the exhaust either.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
88 Notch
Be sure to try the ford OEM PCV rubber grommet. My aftermarket one popped out once i installed the turbo so I got the Ford OEM one and it fits much snugger and has yet to come out.
88 Notchy 306 with 70mm Turbo 510 RWHP on 10lbs K thnx Can we chat? |
1989 Black LX---Turbo
The PCV Vavle is a one way valve. If its working properly it should blow shut under boost and not pressure up the crankcase!
I had the stock PCV and Ford Racing screw in breather on my old 88 with a Novi 1000 @ 10psi and had no oil probems at all!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1992 Lx
11.39@119.24
Shouldn't matter but I think it was pressurizing the crank case and blowing the oil out around the pcv valve so we capped the intake tube and put a breather on top of the pcv valve. See how that works
1989 LX
12.60 at 109mph
well i drove it around and havent seen smoke from underneath the hood or smell oil so hopefully that fixed the problem. Im gonna spray the back of the motor with brake cleaner tomorrow to see if its still leaking.
1993 5.ohhhh
12.97 @140mph
I have a 10psi pulley. Do you want it? 6psi can't be doing it.
1992 Lx
11.39@119.24
will it work on a novi 1000?
1989 Mustang GT 5.0
i kinda have a question myself about this, im going turbo, should i block off the rear PCV as well? and just use the breathers on both valve covers?
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
Threads Similar to: Boost losers, quick question
| Quick question about quick mods for hp | Steelsoldi3r | 96-98 | 21 | January 23rd, 2010 08:07 PM |
| Quick question...need very quick answer-please | ZOOTOXIN | 2005 - 2010 | 11 | December 9th, 2008 10:20 PM |
| alright quick quick light tint question | thorpedo26 | The Clubhouse | 18 | September 1st, 2008 07:36 PM |
