1995 Mustang GT
Engine Mounts!
I have a 95 stang with a cobra swap in it. I have a feeling that the engine mounts are going bad. The car is shaking more than normal at idle and when i rev the car really high the whole car vibrates like the engine is unbalanced or something.
I really don't want to buy the 100 dollar ones off of american muscle. Anyone know a cheeper place? I also would like to know if there is a cheeper ones from a different older mustang. Which engine mounts fit my car. Will cougar ones fit? Ford Explorer ones? I need some help. I'm poor lol |
1992 Lx
11.39@119.24
Go look at your balancer and make sure the rubbers not coming outa it
1996 Mustang 5.0
14.0
Samething happened to me,they break where you they bolt up to the motor well atleast mine did,the car vibrated after 3k or so and got worst,if you replace your mounts get O.E ones and get the convertable mounts,there stronger from what i hear and there the sameones I have.I put them on,omfg i went from a Mustang to a Lexus!!! And there preety easy too,all bolts are right there and the only hard on was on the PS rite next to the starter,but use a swivel and your good.
![]() A Ricer is a stupid young idiot who thinks he is a car expert after watching The Fast and the Furious, Pimp My Ride, and playing Need For Speed Underground-LMFAO |
1996 Mustang 5.0
14.0
Oh yea,I only paid 45 bucks for both no wait 55 bucks with taxes and all..
1995 Mustang GT
i went with the regular OEM rubber motor mounts for a 1995 gt and they are working great so far, i think one was anchor brand and the other one was another, but no complaints so far
93 GT
are we noticing a pattern here?
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
1995 Mustang GT
alright i found the cheep ones. I just don't know if that is the problem. The shaking has kinda gone away now. Idk what the deal is. It was shaking bad over the weekend and this morning everything was good. The shifter has shaken really bad since i had the car. Is it normal for the shifter to vibrate pretty rapid at high RPM's?
1992 Lx
11.39@119.24
no
Like freeway driving?
This is one of the biggest indicators that your harmonic balancer has gone bad... replace it, before you grenade your engine.
1996 Mustang 5.0
14.0
How does the Harmonic Balancer go bad?Isent it metal,what wears out in it?
94 mustang gt
too slow to tell
its metal but there is a rubber ring in the center the blows aparts and then your motor blows so id rather spend the 100 bills or so to replace the balancer
1995 Mustang GT
Best piece of advice ever! The harmonic balancer was bad. I replaced it and now its running like a cadillac. The shifter doesn't shake anymore and the car itself is smooth idling.
1995 Mustang GT
I do have another question though. When i'm driving on the highway, after about an hour of going 70mph there is a weird sound coming from the shifter. It sounds like a synchro speeding up but its not when im changing gears. The sound will continue even when i'm rolling in neutral. If i stop moving for about 10 minutes the sound will go away. Then it will come back when driving again. 3rd, 4th, and 5th gear feel like they are slapping the shifter when i get past 3k rpms.
get the fluid level checked in your trans... sounds like you are running a bearing dry
1994 GT
11.75@120
yea def sounds like a bearing i know the sound my old t5 in the 94 did the same thing but only when i really hammered on it like 2nd thru 4th. check the fluid it might help, but if its a bearing then the damage is probably already done
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers ...E/T: 11.75 @ 120mph 2.0 60foot |
Threads Similar to: Engine Mounts!
| engine mounts | getchapull | 94-95 | 2 | September 7th, 2010 06:52 AM |
| lifting engine off of mounts? | 91cobra5.0 | 5.0 Mustangs | 8 | October 31st, 2008 02:23 AM |
| engine mounts | MikeD05GT | 96-98 | 17 | September 17th, 2008 08:58 PM |
| engine mounts | mmvi | V6 Mustangs | 1 | July 13th, 2007 05:56 PM |
| engine mounts | mustangrebuilder | Classic Mustangs | 1 | November 14th, 2006 06:30 AM |
