Discussing Piston to Valve Clearance in the 5.0 Mustangs Forum. Anyone here ever put a set of AFR185's on a stock block with TF ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Piston to Valve Clearance |
95 opalfrost gt
I dont have 185s but if im not mistaken you will need to notch the pistons.
1990 Mustang LX
9.36@143 mph
You will need to notch pistons with the 185 heads.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
i was told by afr that on the stock cammed 302 block wit afr 185's u will need to notch the pistons, so i would imagine for sure ur gonna wit the trick flow 2 cam
Would Twisted Wedge heads go on the stock shortblock with the stage 2 cam without notching?
#6 | |
1990 Mustang LX
9.36@143 mph
Thanks for the info. I new I should have went with Twisted Wedge heads!
I didn't want to get too involved with this motor. I just wanted to slap a H/C/I combo on the shortblock to play around with. I am going to buy a 393 shortblock this summer so I don't want to invest much into the stock timebomb shortblock. |
Threads Similar to: Piston to Valve Clearance
| Piston to valve clearance. | IcantDo55 | 5.0 Mustangs | 2 | December 30th, 2007 01:04 PM |
| 347? about rod & piston combo | And then some | 5.0 Mustangs | 14 | October 5th, 2007 10:54 AM |
| Help With Piston to Valve Clearance | 1WLDSTANG | Engine | 2 | November 12th, 2006 06:11 PM |
| PISTON ? | 89GTCONV | Engine | 1 | June 14th, 2006 09:44 PM |
| PISTON TO VALVE CLEARANCE FUNDAMENTALS | 173speed | 5.0 Mustangs | 0 | October 7th, 2005 09:47 PM |
