Brake Booster ???'s
Old November 16th, 2010, 11:41 AM   #1
WhiteMamba's Avatar
88 Notch
WhiteMamba is on a distinguished road
Brake Booster ???'s
My car has an air noise when I hit my brake pedal...also on occasion my brakes seem to be non existant when I hit the pedal. Other times it's perfect. Seems to be when I pump the brake I have no brakes and when I hit it hard the first time there perfect.
Is this a bad vaccum on the booster or a bad booster? I see the large vaccum line going to my booster...should I replace that first?
Thanks
88 Notchy
306 with 70mm Turbo
510 RWHP on 10lbs
K thnx
Can we chat?
Old November 16th, 2010, 11:44 AM   #2
1992 Lx
11.39@119.24
bad brake booster=brakes hard as fuck to push
bad master cylinder or leak somewhere=brakes losing pressure and pedal going to the floor
Old November 16th, 2010, 11:49 AM   #3
WhiteMamba's Avatar
88 Notch
hmmm...well it's not happening all the time...but my brakes can be hard to push. Is this indicating a leak as it is not consistant?
88 Notchy
306 with 70mm Turbo
510 RWHP on 10lbs
K thnx
Can we chat?
Old November 16th, 2010, 11:59 AM   #4
1992 Lx
11.39@119.24
could be. If theres a leak anywhere on the master cylinder, its bad. Usually where it bolts to the brake booster. Any fluid coming outa it means the seals are bad
Old November 16th, 2010, 12:07 PM   #5
MntlKase's Avatar
95 GT
13.885@99mph
MntlKase is on a distinguished road
13.6 @ 127? mph seems kinda high don't ya think? I run 13.8 at 99-100mph. anyway, ya right on track with brake issue.
back on topic
The day I lose to a Honda, I'm buying a hybrid.
Old November 16th, 2010, 12:11 PM   #6
1992 Lx
11.39@119.24
my g-tech is more accurate than any dyno or track on the planet
Threads Similar to: Brake Booster ???'s
Brake booster JASonic 99-04 20 February 22nd, 2009 02:25 PM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
Brake booster line? mustangmanic 99-04 16 September 3rd, 2007 01:34 AM
Brake booster kwill5 96-98 11 August 10th, 2007 09:54 AM
brake booster swap??? OTreborO 5.0 Mustangs 7 June 2nd, 2006 04:31 PM
