#21 |
1991 Mustang LX 5.0
Since I don't mind threadjacking... What's involved in getting my wife's tire's (it's a '99) out a little farther, and what would you recommend. How big of a spacer can I use without longer studs, or adapters with studs. I'm guessing only 1/4 inch, but I think 3/4" per side would look better.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#22 |
1999 cobra
you can use 1" or 1.5" I had 1" spacers with 17x9 wheels on my 2003 v6 and it came straight with the fender.
#23 |
I wouldnt personally go much past 5mm on a floating spacer (not bolted on)
You can however go on A-DAPT-IT USA Wheel Adapters and order some spacers. Superb quality, made to order, and they are hub-centric IIRC (aids in vibration reduction)
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
#24 |
1999 cobra
How much HP will the gt40 stuff with the e303 cam make?
#25 |
260-ish
get a better cam
#26 |
1999 cobra
I checked the rear its a 8.8". Is it worth it buying gt40 heads and intakes then porting them and getting a better cam or just getting the TFS kit?
#27 |
depends on who does the porting
contact TMoss, here on the forum
#28 |
1991 Mustang LX 5.0
The TFS kit will net you better gains for sure, then you'll have something better to build off of if you stroke someday.
#29 |
1992 Lx
11.39@119.24
tf heads are on sale right now reggin
#30 |
1999 cobra
what suspension setup should i get?
