1999 cobra
How much HP?
I have a 1995 mustang GT this is what the car has now:
e303 cam CAI A/C delete 93 race tune from Bama Tuning longtube headers no cats, flowmaster 40s How much HP you think it should have, I know there is no accurate answer but around what HP range will it be in. Also it has a 9" rear with 3.73 gears and lightened flywheel, what numbers can it do in the 1/4 mile? |
1993 5.ohhhh
12.97 @140mph
That 9 inch rear robs power and is heavy as hell. Can't imagine why anyone put one in an sn95.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
1999 cobra
I just got the car a week ago and the previous owner said its a 9" rear and also that rear is making a lot of noise when I drive
i would guess 230-240 to the wheels..
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1990 LX hatch
ima say 190-205 at the tires
Ooops...i meant 230-240 to the crank...What JBIG said...
1999 cobra
The guy I bought it from showed me a time slip that he did a 13.4 in the 1/4 mile.
1999 cobra
I want 300rwhp how can I do this without taking the e303 cam out? What can I get to upgrade the suspension for the track/street?
1991 Mustang LX 5.0
I'm going to doubt that it has a 9" in it. Costs more money than it's worth considering an 8.8 is plenty strong. I bet he was just rounding up.
Edit: Sorry, forgot to actually answer your question. I say 235-240 at the crank.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 Last edited by FastStang91Lx; November 16th, 2010 at 07:27 PM. |
1999 cobra
He said it has a 9" cobra rear end I think his lieing how can I tell if its a 8.8"?
1992 Lx
11.39@119.24
My car made 301 with e303, afr 165s, eddy performer and shorties
1991 Mustang LX 5.0
If there is a differential cover on the back with bolts, then it's not a 9 inch. The driveshaft side on a 9 inch comes out, sometimes called a pumpkin. The driveshaft side of an 8.8 in not accessible. Only from the back. I can't say about the older cars, but all newer (even cobra's) were 8.8's
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Mustang LX 5.0
This is what a 9 inch looks like from the back Google Image Result for http://image.dieselpowermag.com/f/19135593+w750+st0/0907dp_06_z+1998_ford_ranger+ford_9_inch_rear_axle .jpg
This is what an 8.8 looks like from behind Google Image Result for http://eastcoastgearsupply.com/images/F7337757.jpg
1999 cobra
I have to check tomorrow if its really a 9" rear becuase I can't find any parts for a 9" rear. Can gt40 intakes and heads with e303 cam make 300rwhp?
1991 Mustang LX 5.0
You would just need to look specifically for ford 9 inch parts, not mustang and choose 9 inch as an option. Ford 9 in are in Tons of high horsepower vehicles as well as street rods, circle track cars, dirt track, etc. But I doubt you have one, don't worry. There have been people that think an 8.8 and 9 are the same thing before, so I'm sure that's just the case.
As far as Gt40's and E cam making 300 rwhp??? Not unless you slip the dyno operator some coin for fudging the numbers. It generally takes a much bigger cam to get there, and ported parts.
1969 Mustang Mach 1
6.824@101.61
Any reason you don't want to ditch the E303?
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1991 Mustang LX 5.0
Cuz they're the shit!... or NJ is an emissions state
98 Mustang GT 4.6L v8
230-240 at the crank is probably right on. As of now my car has 214rwhp on dyno with the mods in my signature....For now
![]() 3:73 gears, Steed tri-ax, Mac o/r pro chamber mid pipe, w/ 2 chamber 2.5” Flowmasters,C&L upper plenum, Livernois PI intake swap kit, Steeda timing adjuster 16', FR 70mm throttle body, FR aluminum driveshaft, Lowering springs, BBK CAI |
1999 cobra
I thought since the e303 cam is in there to keep it there and yea NJ is a emission state. I'm still going to school (High School) so I wont be doing any engine work till winter or spring break so right now I am saving money and planning on what to do.
i say we need pics of the rear end, because those wheels are lined up just like stock
Captain Obvious says: Sellers are usually stupid... and buyers, typically worse!
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
