1988 Mustang GT
Transmission help
i have an 88 mustang i bought it about a year back and i have been doing body work to it. i found that it is extremely hard to shift. ive been told it could be the synchros or the clutch but im not sure. it has the transmission out of a 4 cyl mustang. any suggestions would help, thanks
95 mustang gt
what do you mean hard to shift? does it grind or is it just real stiff going into gear?
1988 Mustang GT
its really stiff. when its been sitting for a while it will be smooth untill it gets warmed up.
86 Mustang GT
Just find a used T5 trans and run it. It's not worth repairing that trans. Replace the shifter assembly while you're at it. I guess it's possible that the clutch is not disengaging fully.
1988 Mustang GT
im on kind of a tight budget but its something i will look into. after i do some work to the engine im thinking of getting a tko
86 Mustang GT
If you do some work to the engine, take it easy on that 4cyl trans. Don't spend more than 100 bucks on a used t5, but a tko is a whole world away from anything stock ford, and will stand up to abuse for the life of the car (maybe). With some searching and patience you can build ass-kicking cars for pennies if you're willing to run used parts.
1991 Mustang LX 5.0
used t5's are 300 here. Wanna ship me some
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1988 Mustang GT
ohh that would be nice to get a t5 for under 100 but sadly ill probably pay about 300 also
1991 Ford Mustang GT
your clutch cable maybe stretched out
1988 Mustang GT
yea the clutch cable is something me and my brother are going to look at very soon, but doing a little research im probably just going to put a better t5 the 4cyl ones dont hold together to well
1988 Mustang GT
just found a T5 tranny local for 300, after i get it out the paint shop that will be my next priority
Threads Similar to: Transmission help
| transmission | 1987mustanggt | 5.0 Mustangs | 22 | September 10th, 2010 08:03 PM |
| Need New Transmission. ?which? | Draidin | 99-04 | 15 | December 27th, 2008 10:48 AM |
| What Transmission to use???? | 05mustang_TT_charged | 2005 - 2010 | 23 | July 10th, 2008 10:38 AM |
| transmission | noob | Modular Mustangs | 11 | April 2nd, 2007 01:11 AM |
