my radio keeps going off
hi can anyone help me . i have a 1987lx convertible i just changed my pullys, and when i slow down my radio keeps going off then a few seconds it comes back on agian. i bought the car in californa, i'm from ny. it has an after market radio in it. it used to shut off once in awhile but it really does it now ever time i start putting on my brakes and slowing down. also my stock temp gauge keeps moving up and down it'll go to the o and then onnce i'm driving for a while it'll go to the red. then it'll go back to the middle,but it never stays still. i can sit there and turn my lights on and the gauge moves it up then when i shut off my lights it'll go down. do i have a short somewhere and if so how do i find it thanks, please help me.
1991 Mustang LX 5.0
I think you have a ground issue. I believe you need you get your head up under the dash and start redoing all the grounds under the screws. Scrape the metal before you put the ground ring (or fork) back on. Look around, there is a few.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
put your stock pullies back on, get your alternator and battery tested
[URL="http://providence.craigslist.org/cto/2148862880.html"]1994 Cobra For Sale[/URL] [SIGPIC][/SIGPIC] [QUOTE=Timm10221]Its only a 10 inch Tach that sits right in the center of the dash with LED lights and a Spinner bezel that has dimonds and gold plating.. And when you hit 4500 plus is sounds off (AAHHH SHITT) :cool:[/QUOTE] |
86 Mustang GT
it sounds like something is wrong w/the charging system, but test the battery anyway. It may also be an issue with the stereo ground itself. My guages do funny shit too. Probably bad grounds behind the dash, or some voltage regulation problem.
1990 mustang gt
It's probably the charging if it only shuts off at lower rpms. When you put the underdrive pulleys it makes the Alternator turn slower. Therefore less voltage. If your Alternator was already weak, its even weaker now. Get it tested like mentioned above.
Burning Rubber in the 5.0 http://www.youtube.com/watch?v=mKGSmRkKQcM95 95 mark8 lsc 95 tbird v8 90 mustang gt 07 silverado v8 08 yamaha r6 to be continued........ foxbodyperformance.com is the way to go |
1991 Mustang LX 5.0
Do all of the above. If you had weak grounds, weak alternator, weak battery, etc.... the problem is only going to be magnified by the use of underdrive pulley's. March Power and Amp series are the only way to go...
radio shuts off
hey thanks for the replie the battery is only 4 months old, i took my tester out and it's fully charged, i think the alternator is the original one, should i replace it or check the voltaged alternator, i don't know where that is, could somebody tell me how to check that.
1991 Ford Mustang GT
take your alternator to have it checked at the auto parts store they will do it for free
1990 mustang gt
Turn the car on, and unplug the battery. If the car dies your Alternator is bad.
Dont ever do this. It can cause a power surge in the alternator that can not only fry the internal electronics of the alternator itself, but possibly some of the electronics in the car itself (like your ECM)
88 Mustang lx
+1 on not doing that ^ and get it done for free or if you have a multi-meter you can simply check it!
Threads Similar to: my radio keeps going off
| CB Radio Help | MustangMatt96GT | The Clubhouse | 32 | December 24th, 2008 02:12 PM |
| My new radio! | gooberhead320 | The Clubhouse | 5 | August 8th, 2008 01:46 AM |
| Radio | BoomerSixZero | Classic Mustangs | 2 | December 30th, 2007 10:03 PM |
| radio | indign | Audio/Video | 9 | March 21st, 2007 03:47 PM |
| 05+radio | Ware | Audio/Video | 7 | March 10th, 2007 12:08 PM |
